3-Point Hitch Do I need to hold 3 point lever down during operation?
   / Do I need to hold 3 point lever down during operation? #1
snpower
Charlottesville, Virginia
John Deere GT235, GT 275, 1025R
Does holding it down offer any advantage or disadvantage when using a rake, box scraper, etc? Thanks guys...
   / Do I need to hold 3 point lever down during operation? #2
If it is an increase in implement down pressure you have in mind, nothing is gained by holding the lever down.
   / Do I need to hold 3 point lever down during operation? #3
It keeps the implement from rising off the ground when the front wheels drop into a dip or when the rear wheels rise on a bump. That's useful when you are crossing uneven ground.
Bruce
   / Do I need to hold 3 point lever down during operation? #4
Bruce
It does?
   / Do I need to hold 3 point lever down during operation? #5
Once the lever is at the bottom it does not need to be held as only the weight of the implement will hold it to the ground.
   / Do I need to hold 3 point lever down during operation? #6
Holding the 3ph lever down will allow the 3 point hitch to float. You can adjust the return spring so that you don't have to hold the lever in the down position. That is what I did and it works for me.
   / Do I need to hold 3 point lever down during operation? #7
There is an old thread on this with a lot of information on the non position control 3 point.
   / Do I need to hold 3 point lever down during operation? #8
yes and no. Depending what you are trying to do. For example I was tilling my garden a month ago and its on a slope. When I reach the bottom at end, there is a dip. As I am going thru the dip, the 3 pt appears to be down all the way until the rear tires is on "solid ground" on the lawn area and this seems to lift the tiller but really the valve on 3 pt is "closed" so it kept the 3 pt at the same low point it was so the tiller is not going as deep to till at the end. So pushing down on 3 pt just keeps the valve open so it can float and it will follow the ground.
Everyone's reply has been helpful and in line with my thinking. Thanks!
2017 Ford Taurus SEL Sedan (A48082)
2017 Ford Taurus...
UNUSED KJ 42' X 30' METAL STORAGE SHED (A50460)
UNUSED KJ 42' X...
2012 CATERPILLAR CS44 SMOOTH DRUM ROLLER (A50458)
2012 CATERPILLAR...
2007 Toyota Tundra 4WD Pickup Truck (A50860)
2007 Toyota Tundra...
2016 John Deere TS Gator 4x4 Utility Cart (A49346)
2016 John Deere TS...
2014 Ford C-Max Energi Hybrid Hatchback (A48082)
2014 Ford C-Max...
