Do I Need 5/16 or 3/8 G70 Transport Chain?
   / Do I Need 5/16 or 3/8 G70 Transport Chain? #1
trook
North Central Mississippi
JD 5075E Cab
I am currently hauling a JD 3320 on a 18ft utility trailer. Should I use 5/16 or 3/8 G70 transport chains? The tractor itself weighs about 3000lbs. However, I have loaded rear tires, a FEL and always have some type of attachment on the rear (5ft rotary cutter, etc). Is the 5/16 enough?
   / Do I Need 5/16 or 3/8 G70 Transport Chain? #2
i believe the 3/8 chain is rated at 6000 pounds. not sure about the 5/16
   / Do I Need 5/16 or 3/8 G70 Transport Chain? #3
The Working Load Limit (WLL) for Grade 70 Transport Chain is 6600 lbs. for 3/8" and 4700 lbs. for 5/16", according to a chart I downloaded from a chain supplier. Sorry, don't have the link:( but I got it by googling.:)
   / Do I Need 5/16 or 3/8 G70 Transport Chain? #4
Pulled this out of a PDF that was post on TBN.
So far, it sounds like 5/16 grade 70 on all four corners will be more than adequate for this tractor. The total weight with FEL, 3pt attachment, etc should never exceed 6k lbs
   / Do I Need 5/16 or 3/8 G70 Transport Chain? #6
The total WLL has to equal HALF the weight of what you are strapping down.
But you need a minimum of two chains (straps, whatever) for vehicles under 10,000lbs
so two 5/16 G70 with appropriate rated hooks and binders will be PLENTY.
   / Do I Need 5/16 or 3/8 G70 Transport Chain? #7
At that rate one 5/16 would be enough to tye down three tractors:D
   / Do I Need 5/16 or 3/8 G70 Transport Chain? #9
cargosecurement-16-04.pdf
Pg 124 is where I got the above image I posted about WLL
Pg 102 is the statement "Use at least two tiedowns at both the front and rear of the cargo to prevent movement."
   / Do I Need 5/16 or 3/8 G70 Transport Chain? #10
I believe you are correct, wheeled vehicles require 4 chains/4 binders. There are many other posts on this topic.
To answer the original question 5/16" will be plenty.
2013 KOMATSU D39EX DOZER (A43003)
2013 KOMATSU D39EX...
Case 821B (A42021)
Case 821B (A42021)
Sakai SV70TB (A42021)
Year: 2011 Make: Ford Model: Expedition Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: (A44572)
Year: 2011 Make...
New/Unused Self Dumping Hopper (A44391)
New/Unused Self...
Heavy-Duty 4-Wheel Rolling Warehouse Cart  74in x 32in (A44789)
Heavy-Duty 4-Wheel...
