daugen
Epic Contributor
I am considering buying one of these high end mowers and mowing my own 8 acres again instead of a mowing service which I tried
out this year. Service costs me almost 10k per year. Huge amount of weedeating, orchards, fences, etc. I mow my two orchards anyway, one fenced, but they weedeat.
So am considering going back to what I did the year before when I mowed with my diesel JDX750 with a 60 deck. It takes me a long time to mow all of it, and for sure a lot of trees to get under and around. Figured the outfront deck was the most efficient. My older brother has owned one for almost twenty years and it keeps on mowing.
By reading other threads here on these mowers, learned I want a rear discharge. All that grass no longer going into my mulched rose garden...
I also want to consider the mulching kit. Plus the air seat. Grass is mowed in 2 to 2.5 inch range. Centipede, Bermuda and fescue, a real mutt. Plus 4 acres of field grass which is turning into nicer lawn slowly cut at about 3.5 inches. Like the taller look, don't want it to look like a lawn. I also cut that grass with my Kubota tractor and seven foot LP finish mower, which is rear discharge, and which with sharp blades is 95 percent the equal of the smaller decks. Helps to have totally flat lawn/topography here, plus ditches. But of course you can't get very close to anything with the tractor and I always worry about smashing the rear mower into something on turns. Hired help regularly scalps edges of ditches due to poor skills and going too fast.
Lastly I have physical limitations, bad right arm and hand, losing grip, need a steering wheel, not levers(gave up beautiful Ferris Zturn with suspension years ago) with the lightest possible steering effort.
So, you Kubota experts, is it worth $3,275 to add the 4wd? No traction issues here at all, maybe a one degree slope in some areas for water drainage.
My automatic default is to choose 4wd, but maybe not. Which one rides better? Has easier steering?
Sounds unlikely I'll find one of these sitting on my local
Kubota dealer's lot.
Thanks for all input. Drew
