Hello All.
Thank in advance for all you help.
I have upgraded my tractor hydraulic pump from a 8.5 GPM to a 13,5 GPM pump on my 24 HP tractor, I needed the speed.
Now I am starting to wonder if maybe this pump is too large for my tractor. The reason is: When I go to end of stroke with my front end loader the engine RPM decrease more than usual, quite much to be frankly. If running at idle 1000 rpm it will decrease down to only 500 rpm when I go end of cylinder stroke and the PRV kicks in. It stays bogged down even when relieved.
If I'm pushing into a pile of sand with the loader in high rpm (2200 rpm) and try to curl the bucket the PRV kicks in and a lot of whining noise can be heard and I'm not able to curl the bucket with the sand. But If I decrease the RPM to lets say 1000 rpm, I can easily curl the bucket with the same amount of sand I tried in 2200 rpm.
What do you guys think? Do you think my PRV is to small for this amount of flow, or is my pipe dimensions undersized for this flow causing a pipe restriction at higher rpm (flow) which make the PRV open at even the smallest restriction cause by the curl cylinder? Or any other problem I have?
I have not tampered with the relief valves which is set at 2300 PSI according to the books.
Thank you very much for your help!
Bill
Bill
