Do I have to full stop to go into 4WD on L4300, MX5100 and others?
   / Do I have to full stop to go into 4WD on L4300, MX5100 and others? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
Reading my owner's manual again, I noticed it says that you are supposed to come to a complete stop before engaging the 4WD. I guess I do that most of the time but there have been occasions when i started to slip at a slow speed and just pulled the 4Wd lever to engage. I thought it was OK to do this.
I know to follow the owner's manual and I do but wonder what others do with any of the smaller Kubotas since I'll bet they all say the same thing in their owner's manuals . Does anyone else occasionally engage 4WD while moving and what can go wrong in doing this?
   / Do I have to full stop to go into 4WD on L4300, MX5100 and others? #2
I have a 3400, and engage it while moving, but I dont if the wheels are slipping or something. But just cruzing along, like going from the road or drive onto the yard, I dont stop to engage.
I suppose the harm would be to wear out the shifting mechanism or gear a bit sooner. (I dont know how its designed). But since there is a tad bit difference in speed of the front and rear axle by design, thats probabally why they want you to completely stop??
   / Do I have to full stop to go into 4WD on L4300, MX5100 and others? #4
I engage while moving, but I "ease" it in (ie push down gently and feel when it slides easily into place). I dont force it in.
Aaron Z
   / Do I have to full stop to go into 4WD on L4300, MX5100 and others? #5
I often find it difficult/impossible to engage/disengage when dead stopped. A little travel speed & no load seems to be best - if you're moving & it won't engage, then try while you back off the throttle. Also, sometimes turning the steering wheel while trying to engage at a full stop works.
   / Do I have to full stop to go into 4WD on L4300, MX5100 and others? #6
I'm too uncoordinated to change mine on the L5740, but do on the BX and M8540.
   / Do I have to full stop to go into 4WD on L4300, MX5100 and others? #7
I shift mine stopped or at very slow speed. To disengage I sometimes backup a few feet to relieve the winde up and make it easy.
The mechanic at my dealers said they were square gears and to be very careful when engaging/disengaging 4wd. He said just find a way to do it w/o grinding the gears.
   / Do I have to full stop to go into 4WD on L4300, MX5100 and others? #8
Just as any 4 wheel drive, they don't want you spinning wheels while slipping or stuck. Chances are it will just grind and not engage and potential damage a gear. Shifting on the fly is ok while not slipping an steering straight
   / Do I have to full stop to go into 4WD on L4300, MX5100 and others? #9
Disengaging works well on all our tractors going straight - hit the gas momentarily then back off while quickly operating the lever.
larry
   / Do I have to full stop to go into 4WD on L4300, MX5100 and others? #10
larry
Well I tried this a couple times today coming out of the woods and it worked good. Thanks Larry
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2022 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
2014 Doosan DA30 (A51039)
2014 Doosan DA30...
90018 (A48082)
90018 (A48082)
2007 MACK GRANITE ROLL OFF TRUCK (A51222)
2007 MACK GRANITE...
2022 Ram Bighorn 2500 4X4 (A51039)
2022 Ram Bighorn...
