DK55C PTO Trouble
   / DK55C PTO Trouble #1
billr3408
My PTO stopped while I was using it. The 10amp fuse is OK and I switched the PTO relay to another spot and it worked OK. I don't have a light on the wall switch or on the instiment panel. What now?
Thanks,
Billr3408
   / DK55C PTO Trouble #2
Not that its the same tractor but my neighbor has a 33ish HP JD. His pto stopped working and we did all the same things you did. The dealer came out and its was a wiring harness that came un-plugged. It was under the tractor down around the rear axle. May want to follow the wires.
Chris
   / DK55C PTO Trouble
Thanks,
Billr3408
Thanks Chris,
I'm thinking it's an electrical issue. I'll try to track it down tomorrow.
Bill
   / DK55C PTO Trouble
Fixed!!!
I had a short in the power lead running up to the wall PTO switch. Ran a new line and all is well with my DK55C Kioti.
Bill Riley
CRAFTSMAN ZERO TURN MOWER (A53843)
CRAFTSMAN ZERO...
Electric Mobility Scooter (A51694)
Electric Mobility...
RYOBI 2900 PSI GAS PRESSURE WASHER (A51248)
RYOBI 2900 PSI GAS...
2014 Jeep Grand Cherokee SUV (A51694)
2014 Jeep Grand...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A53843)
2011 MAGNUM...
2018 Komatsu WA380-8 Articulated Wheel Loader (A51691)
2018 Komatsu...
