Dk5310se ballast question
   / Dk5310se ballast question #1
Jturning
KiOTI DK5310SE cab hst
I have a DK5310 on the way, I am building a ballast box and wonder how much weight I should have? I read the manual and it states to just have ballast, with no mention of how much. I am having the rear tires loaded with rimguard about 900lbs but wonder how much I should have out the back? Thanks
   / Dk5310se ballast question #2
It really depends on how much weight you're going to be working with up front, I see most guys just hook up to a piece of equipment such as scraper blade etc. and use it for ballast. I think if I were going to build a ballast box, I would probably shoot for something no less then 500 lbs.
I have a grapple on order, but it will not show up until spring. I have a sawmill and plan on using the full capacity of the loader.
   / Dk5310se ballast question #4
I ordered a 4 in 1 bucket and it's 10 - 12 weeks out also.
   / Dk5310se ballast question #5
i have a dk45 cab with loaded rear tires. my ballast box holds 1,000# of concrete. no issues what so ever.
Thanks, I was thinking 1000 pounds would be a good target.
   / Dk5310se ballast question #7
I saw/heard a suggestion recently on I think the "Good Works Tractor" channel (YouTube) where he suggested looking at the manual for a comparable Deere or Kubota model to get an idea of ballast.
I just wish I could get a good quality non freezing liquid ballast down here in southern California.
Dave
   / Dk5310se ballast question #8
I have the DK5810 with water in the rear tyres, ballast box about 600kg, often picking up 1000kg bulker food bags...... very carefully.
   / Dk5310se ballast question #10
I use 1100 lbs plus have filled rears.
2011 Chevrolet Colorado LT Pickup Truck (A50323)
2011 Chevrolet...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER TRUCK (A51222)
2019 INTERNATIONAL...
2015 MACK GU713 DAYCAB (INOPERABLE) (A50854)
2015 MACK GU713...
2020 John Deere 35G Mini Excavator (A49461)
2020 John Deere...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A50322)
2025 78in Dual...
