Oil & Fuel DK45SEH replacement filters
   / DK45SEH replacement filters #1
Ranchdog
Rogue River, OR>
David Brown 990
Have any of you Kioti owners found a reliable source for replacement filters other than the dealer network?
   / DK45SEH replacement filters #3
The dealer network is the best place to get your filters. The KIOTI flow rate is higher compared to most competitors, and aftermarket filters tend to restrict the flow, which can result in overheating your pump and ultimately could lead to pump failure. Using the KIOTI filters for engine and hydraulics is highly recommended. KIOTI lists a bunch of approved brands and weights of oils, other than their own, if you want to run a different fluid, but I would not run aftermarket filters. Hope this helps.
2023 Bobcat T770 Skidloader (RIDE AND DRIVE) (LIKE NEW) (A50774)
2023 Bobcat T770...
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
2015 Ford Escape AWD SUV (A50324)
2015 Ford Escape...
2003 Ford Excursion 4x4 (MPV), VIN # 1FMSU43PX3EC07978 (A51572)
2003 Ford...
STORAGE FEES (A52141)
KJ (9) 5'x5'6" Wire Mesh (A50121)
KJ (9) 5'x5'6"...
