Oil & Fuel DK45SE starts hard when hot?
   / DK45SE starts hard when hot? #1
tractorsam
New Germany, NS
Kioti DK45SE HST Cab
I've noticed that my DK45SE seems to start hard when hot. I don't mean after it's been warmed up but when it's been working hard for an extended period. It will crank over just fine but it acts like it doesn't get fuel right away (no smoke while cranking) and then it will slowly start to fire and then pick up RPM and it runs fine after that. Normally when it's warmed up you just flick the key and it's going, when this happens it might crank for 5 seconds or so before starting. Has anyone run into this before? No difference before or after a new fuel filter. Thanks, Sam
   / DK45SE starts hard when hot? #2
Hasn't happen to my DK45se specifically, but here are a few thoughts that may help.
Could it be a poor battery or starter that is now more easily heat soaked?
poorly contacting relay when hot?
any harness connection that becomes a bit more loose when warm?
bad fuel pump that has a hard time priming when things are warm and thin?
How many hours on your tractor?
Cranks the same speed hot or cold so I doubt it's a starter issue, also I see no smoke from the exhaust. Currently 550hrs. Thank you. Sam
   / DK45SE starts hard when hot? #4
Hot start problems associated with fueling tend to be IP-related.
Top of this forum is the sticky about failed/failing IPs. If yours is a 2005-2008(?) model then this could be something to check out.
   / DK45SE starts hard when hot? #5
Mine has never done this.
   / DK45SE starts hard when hot? #6
I haven't heard of this symptom before but two possibilities come to mind. First (and less likely) air somehow gets into the fuel system and all that cranking is needed to purge air from fuel lines, etc. The second possibility is binding of the IP rack or maybe the governor, but only when very hot. if you can remove the oil-fill plate when it's having the problem it should be easy (in theory) to check for IP rack or governor binding. In practice this may not be easy because everything is hot (ouch) and may cool before you can get the plate off.
The tractor is a 2010. Hadn't thought about the rack sticking, good to know it's easy to check. Thanks, Sam
2006 Dodge Ram 3500 Pickup (RUNS)(TITLE) (A50774)
2006 Dodge Ram...
2014 UTILITY 53X102 DRY VAN TRAILER (A52141)
2014 UTILITY...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
2010 Ford F550 Service Truck (TITLE) (NOT RUNNING) (A50774)
2010 Ford F550...
2014 Infiniti QX60 SUV (A50324)
2014 Infiniti QX60...
2007 GMC W4500 Landscape Dump Truck (A50323)
2007 GMC W4500...
