DK45SE oil drain plug threads- size?
   / DK45SE oil drain plug threads- size? #1
Mark Headley
Bronze Member
Randle WA
2012 DK45SE-HST Kioti, JD X758
Wanting to get a magnetic tip engine oil drain plug- does anyone know the size and pitch? 12x1.25mm?
   / DK45SE oil drain plug threads- size? #2
Hey Mark,
not sure if this helps, but I have a 2014 CK30 and I wanted to replace the oil drain pan plugs (2), and found out that they were the same as my 2013 Toyota Tacoma v6 4x4.
Here is the link for the plugs from Gold Plug, although I can't be sure that my size will fit your tractor. Keep us posted, Dutchy
Search Results kioti - Gold Plug LLC – Magnetic Drain Plugs
   / DK45SE oil drain plug threads- size? #3
12x1.25 is correct. I know cuz I stripped mine and had to retap to 1/2×20 :(
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A52128)
Kubota 24in Quick...
2023 CATERPILLAR 279D3 SKID STEER (A51242)
2023 CATERPILLAR...
McKee 504 3pt. Snowblower (A50774)
McKee 504 3pt...
2022 BARFORD TR8036 MOBILE SCREEN (A51242)
2022 BARFORD...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
2019 CATERPILLAR 299D2 XHP SKID STEER (A51242)
2019 CATERPILLAR...
