DK45SE HST won't start
   / DK45SE HST won't start #1
Claude88
Brighton, Ontario
Kioti DK 45 HST
My DK45SE HST won't start .
the first sign of trouble was a few weeks ago when it didn't start and i moved the range lever to high and back tolow then it started. then a week ago it needed many changes of the range lever to then finally start.
Now it doesn't start at all.
It has 104 hours, all manitenance done, full of fuel, battery fully charged. oil marking 2/3 on the dipstick full range.
Any body else that may of had this problem.
Claude
   / DK45SE HST won't start #2
I assume you mean it won't crank, not that it won't start. (big difference) I assume all the normal lamps on the dash are lit. (goes thru glow cycle, but the Neutral lamp is not lit? And I assume you have already diagnosed the problem. as the safety switch itself or connection to the switch because of your prior experience with the failure.. I am also assuming that you have made sure that the PTO is turned off, and the cruise is off. I would think the switch is bad or the linkage is misadjusted to the switch. But that is based more on your prior experience than anything else.
James K0UA
yes it acts like it is in low med or high ie does not crank or any noise at all when in neutral .I suspect it is electronic..
I have checked all that you have mentioned.. except for cruise. I will switch the pto on and off to see if that works.
it is currently off
   / DK45SE HST won't start #5
Sounds like the same problem I'm having with a DK40 SE HST. (NEW) I have to turn the key to the "Start" position several times to finally get it to make contact. A question to the dealer about any known problems with this model resulted in the shipment of a new ignition switch. I'll let you know what happens when I install it.
   / DK45SE HST won't start #6
It does sound like a bad connection is preventing the transmission from either recognizing or going into neutral and it will not start if not in neutral. Does the N light light up on the instrument panel?
   / DK45SE HST won't start #7
That would tell us a lot right there, if the N lamp was illuminated or not, if not then the problem is likely the safety switch on the hydro range lever, or its connection. If the N lamp is illuminated but still will not crank, then perhaps the notorious key switch.
James K0UA
yes the indicator lights al work I am wondering if the switch does?
   / DK45SE HST won't start #9
Switch sounds likely to be the problem. Is your tractor kept outdoors in the rain? I haven't heard of a lot of DK ignition switch problems yet but the CK guys certainly have had their share and the key works in both!
yes I have only lately as I have had to store things in my garage
can clening the ignition switch help?
2009 Freightliner B2 School Bus (A51692)
2009 Freightliner...
2014 Bandit 4000T Foresty Mulcher (A52384)
2014 Bandit 4000T...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
1992 Effer 7600 2S Knuckleboom (A51691)
1992 Effer 7600 2S...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
LOT NUMBER 51 (A53084)
