DK45S 3 pt lift arms inop?
   / DK45S 3 pt lift arms inop? #1
fiddleback
Bronze Member
Stafford CT
2006 Kioti DK 45s
Hi all, as you may remember, I just bought the tractor a few weeks ago with a Woods backhoe on it. So I never thoght of operating the lift arms because I thought the hoe might be in the way or something? Anyway, today I took the backhoe off for the first time and tried to hook-up a bushhog. AND I'LL BE DANGED if I cant get the arms to move,lift or anything! I had it installed new with dual remotes so maybe something wasn't put back right at the dealer?
I overviewed the manual and I cant seem to get anywhere?
1 PTO button is off as well as switch on dash in nuetral 2. all 3 gear shifts are in nuetral (i'm possitive). Engine at low idle and parking brake engaged. I've tried everything I know and i'll call the dealer as soon as he opens. Just wondering if you folks have any ideas I can try in the meantime Thanks Tom
   / DK45S 3 pt lift arms inop? #2
Backhoes on compact tractors normally have two hoses that connect the BH hydraulics to the tractor. When the BH is detached, the two hoses have to be connected. I am sure that your model is the same. Did you connect the two hoses?
   / DK45S 3 pt lift arms inop? #3
Dirtcutter had the same problem, it was a valve that has to be turned when the BH is removed. I don't have a BH, but on Dirtcutters it was near the Hydro filter and he needed a wrench or something to turn it. This valve diverts the hydro oil from the 3pt to the BH because both do not operate at the same time. Go back 4 pages and look for Dirtcutters post "box scraper problem".
RD
   / DK45S 3 pt lift arms inop? #4
make sure the remote position lever is in the off netural position
   / DK45S 3 pt lift arms inop? #5
You say you have remotes installed. Make sure you have not left one of the remote levers engaged. When they are engaged they disable the 3pt arms.
   / DK45S 3 pt lift arms inop? #6
It seems that he uses the remotes to power the BH and not the hose kit with the valve that needs to be turned to get the 3pt to work. I use to have the hose kit valve and changed to dual remotes. Easier and more useful with the remotes. Thanks Rick.
As mentioned, center the control levers of both remotes. The one remote, second or outer valve, should have a float function. If it's in float, it works like a bypass and wouldn't let any pressure go to the 3pt. My CK30hst doesn't have it but check your draft control which I think you have. A lesson learned from a friends tractor. No need to worry about connecting any hoses with the remotes and having both centered.
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
SELLICK S80T4E-4PS ROUGHT TERRAIN FORKLIFT (A51246)
SELLICK S80T4E-4PS...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
2007 CATERPILLAR 330DL EXCAVATOR (A51246)
2007 CATERPILLAR...
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
