DK45 SE 750 hour review
   / DK45 SE 750 hour review #1
StuartDK45SE
Angleton, Texas
Kioti DK45SE
Bought the tractor new in 2014. The vast majority of the hours have come from mowing 10 acres either with a 6 ft brush hog or a Woodmaxx FM78 flail mower (sold). To get to the chase, I've had zero breakdowns. Tractor stays inside a barn. I have noticed that the ends of all four of my cylinders on the FEL have a lot of side-to-side slop and a little slop in what I would call the critical "torsion" direction. This is surprising to me as I have always kept everything well greased and the FEL hasn't done any serious dirt work, mostly just lifting things with my grapple , forks etc. It'll have to be addressed at some point.
I'll tackle the 800 hour valve clearance check soon.
Also, I am still amazed that there isn't a more sophisticated diesel filter on this thing, but so far no issues.
   / DK45 SE 750 hour review #2
Just a word to the wise..
Keep a regular fuel filter schedule.. u can’t buy hard parts for those inj pumps..
(Pumping plungers or delivery valves)
U have to buy a complete inj pump.. NOT CHEAP.. the part #’s are captured by the Oem.
   / DK45 SE 750 hour review #3
My loader has a bit more play in the pins than I would've expected, given I've been using moly grease in them, but it has been worked pretty hard, and it doesn't seem to really affect much?
I've never bothered to take a pin out and see what is wearing though? The pin or the crosstube mount.
   / DK45 SE 750 hour review #4
My tractor experience has been basically the same, I replaced the positive battery clamp for a no start condition several years ago. I probably have 150-200hrs dragging around a HD 7' box blade and digging with the loader, maybe 150hrs pushing/pulling snow with a 7' rear blade in mid range, and most of the rest mowing with a 5' rotary mower(should've got a 6' or 6.5') or moving bales, and a couple dozen hours playing around with a 9' haybine(works great!) and 4x5 hardcore round baler(not enough pto hp to do regularly, makes a 4x4 in very low humidity fine).
It also lifts all the things around here, and even wheelbarrows around dead cars pretty easily. I have mine set as wide as it goes with the R1's with the rears loaded as I have few level areas that I don't make myself!
The tie rod ends have bit of play now so I should replace them, and some of the loader pins are a bit worn/loose, but not enough to seem to matter much? And the front tires have some sidewall cracks, maybe from overloading, but they just seemed a bit "dry" from the start.
All in all a good tractor, for most of the things I do. If I got into more hay, I would add a 2wd 65+hp one for that round baler...
   / DK45 SE 750 hour review #5
For the whole KiOti lineup or ??
2023 Ford Explorer AWD SUV (A51694)
2023 Ford Explorer...
2008 Ford F-250 (A53472)
2008 Ford F-250...
2006 CHEVROLET EXPRESS CUTAWAY BOX TRUCK (A52577)
2006 CHEVROLET...
Unused Delta Crash...
(2) Sumitomo 11.00 R22 Tires (A51573)
(2) Sumitomo 11.00...
2022 McConnel TRAXX RC28 43in. Remote Controlled Slope Mower (A51691)
2022 McConnel...
