Mowing DK40se HST Rear remote float detent slope mower need suggestions ideas
   / DK40se HST Rear remote float detent slope mower need suggestions ideas #1
icur2ys4ye
pelham, NH
none
Hi,
I have a dk40se I just picked up a slope mower (ferri zme 155). I have two rear remotes installed on my tractor one has a detent to stay on for the back hoe while the other has no detent. The question is can I add a detent for a float in the second rear remote.
It did come with a set of valve spools that are setup to work with a power beyond If I can't get a float function I am going to just use the a and b ports (the ones with the detent) and use the supplied controls. If I go down this road where should I mount another block of valves where should I put the controls for them?
I don't have any pictures but I will get some soon so you can see what everything looks like.
   / DK40se HST Rear remote float detent slope mower need suggestions ideas #2
The detent position on the Kioti is not for float. It is used to provide continuous hydraulic flow to an attachment with its own control valves, notably a backhoe or a splitter. I don't believe Kioti provides a rear hydraulic circuit with a float function, much to my own disappointment as well.
   / DK40se HST Rear remote float detent slope mower need suggestions ideas #3
The rear hitch only powers to lift. There is no hydraulic power for down (like a FEL). So when the hitch lever is full down it should be free to float. Does the mower have wheels that allow it to follow the ground contours?
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
25 DUAL AXLE GOOSENECK TRAILER (A55745)
25 DUAL AXLE...
CLUB CAR (A55758)
CLUB CAR (A55758)
2015 Chevrolet Silverado Pickup Truck (A55314)
2015 Chevrolet...
Ratchet Straps (A55852)
Ratchet Straps...
