Snow DK40 OEM Snowblower
   / DK40 OEM Snowblower #1
spindlewood
Bronze Member
Northern Idaho
Kioti DK40SE HST Cab
I have a DK40 OEM Front Mount Snowblower and broke the fan shear pin - a rock got wedged in. The manual lists it as an M8 x 1.25 x 35 gr. 6.6.
There is only one place on the whole web which references a grade 6.6 bolt - this post on tractorbynet where the user Chilly807 says that
I believe 6.6 is equivalent to grade 2 in the SAE system, and grade 5 is very close to 8.8 in metric.
Amazing that a reference to this grade is otherwise nowhere to be found. Anyone else ever hear of a grade 6.6 (metric) and does a Grade 2 (SAE) sound right for this? It's weaker than the Grade 5 - and am ok with that as I don't want to risk breaking the PTO shaft. But also don't want to put something needlessly weak into it.
   / DK40 OEM Snowblower #3
I believe you are making spindlewood's point. While your links provide valuable information, there is no mention of grade 6.6. I too searched for 6.6 grade bolts (& shear pins); and came up blank. One contributor made a very convincing argument that using to soft a bolt is not a good idea in that it will likely "smear" as it breaks, making it very hard to get the pieces out - I have had that happen, & it is no fun.
Several people recommend to go to the next harder grade, (grade 5, ot 8.8, in this case) and machine a shear line on the bolt where you want it to break. Makes a lot of sense to me...I personally do not think it is terribly critical, just get as close as you can.
   / DK40 OEM Snowblower #4
Ooops, I guess I read too quickly. I have Grade 8.8 on the brain because the PTO shaft on my new-to-me blower requires a metric bolt Gr 8.8 and I still have yet to pick one up. Definitely have a punch at hand when trying to remove a broken shear pin. As for the grade, I am not a mechanical engineer, but the materials in manufacturing are normally way over engineered to ensure long product life so a presumably a gr 8.8 vs 6.6 bolt would break long before the blower shaft. Some of us are old enough to remember selecting the fuse value for the old fuse panel - dead shorts still blew the fuse!
   / DK40 OEM Snowblower #5
I really suspect it is a misprint by Kioti...there are many typos in my manuals...but I don't know for sure about this.
Thanks everyone for your perspective. I called the dealer and the parts person advised grade 5 - suspecting a misprint as well. So that's what I put in. Hope to never scoop another big rock into the fan again.
   / DK40 OEM Snowblower #7
Yeah i dont have a kioti blower, i have woodmaxx rear blower. The shear bolts for the pto shaft, and chain drive shaft are grade 2 bolts. I have sheared them multiple times with rocks and such but in my experience i would rather have a grade 2 than grade 5. The grade 2 doesnt smear it shears well. I typically install with a slight snug on the lock nut. If theres no play itll shear fine.
I’d rather replace a bolt than busted internals any day of the week thats for sure lol.
2018 TAKEUCHI TL8 SKID STEER (A51246)
2018 TAKEUCHI TL8...
2019 Dodge Challenger Passenger Car (A51694)
2019 Dodge...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
2016 Sure-Trac 20 Ton Pintle Trailer, VIN # 5JW2U2522G1121114 (A51572)
2016 Sure-Trac 20...
1999 LBT INC FUEL TRANSPORT TRAILER (A52472)
1999 LBT INC FUEL...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A52748)
2023 New Holland...
