dk40 fluid leak
   / dk40 fluid leak #1
dogday
I am an new dk 40 owner. It is a gear drive dk40 with creeper that I bought new a little over a month ago and have 5.5 hrs on it now. Walked behind it in the garage and noticed two spots where fluid had dripped out of back axle where the transfer case meets the transmission on both sides. Both drips from the same spot on each side and was just enough to notice something had dripped on the cement. Checked the transmission fluid and the dipstick was dry. Ran the tractor for a while and fluid was on the bottom of the dipstick. Is it normal for the small leak when new? I am more concerned about the low tranny level. Should the level be checked while the engine is running? Tried to contact the dealer I bought the tractor from for several days and have not recieved any reply. Any help would be greatly appreciated.
   / dk40 fluid leak #2
No leaks are normal. I'd make sure the dealer repairs the leak. It may be only loose bolts, but that should have been corrected before it was delivered.
   / dk40 fluid leak
thanks, been trying to get in touch with the dealer but no reply. More concerned about the low tranny fluid though. Is it supposed to be checked warm with the engine running?
   / dk40 fluid leak #4
I check mine when warm, but the engine doesn't have to be running.
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2019 Nissan Sentra Sedan (A50324)
2019 Nissan Sentra...
2007 Brunswick Challenger 27ft Fire Rescue Boat with Tri-Axle Boat Trailer (A50324)
2007 Brunswick...
2015 Ford F-150 4x4 Crew Cab Pickup (A50323)
2015 Ford F-150...
Swict 78" Bucket (A50121)
Swict 78" Bucket...
44505 (A51692)
44505 (A51692)
