DK40-50 SE HST w/ 3rd Function Valve
   / DK40-50 SE HST w/ 3rd Function Valve #1
gkh7890
SW Ohio
DK40SE HST
Hey Pack!
I'm curious if anyone has this setup and if you do, would you mind posting some pics of your lines from the FEL valve......especially if you have a BH hooked up ( I think a couple of you do have this setup...couldn't remember off hand who? :confused:). My best friend has a 40SE HST (like mine) but he also has the Kioti BH and he wants me to add a 3rd function valve for a grapple he plans to buy.
Also, do you know off hand if the valve needs to be open center, closed center or float center. Going to buy a valve from Northern Tool (at this point). Got all the other parts spec'd out, just need to determine the type of valve to buy. I've not called my dealer as that last time we talked about this, he couldn't help b/c he hadn't worked w/ these valves at all.
Any and all assistance is greatly appreciated!!!
Thanks!
Greg
   / DK40-50 SE HST w/ 3rd Function Valve #2
I've got ALL of the above. DK-40, KB-2485 hoe, front grapple, two pairs of Kioti rear remote kits, AND a top-n-tilt setup from Brian, of fit-rite hydraulics, an approved advertiser from TBN. Look him up, he can get what you need.
CM,
Thanks. It looks like Fit Rite valves are diverters vs. electro-hydraulic? Do you know for sure which one you have?
   / DK40-50 SE HST w/ 3rd Function Valve #4
Electro hydraulic divirter. Brian can tell you more than I can.
378715 (A51573)
378715 (A51573)
2012 DIAMOND CARGO FOOD TRAILER (A52472)
2012 DIAMOND CARGO...
2013 CAT 950K WHEEL LOADER (A52472)
2013 CAT 950K...
2003 FONTAINE TL50-NGB TRI AXLE RGN TRAILER (A52576)
2003 FONTAINE...
