DK40 3pth bounce and flex?
   / DK40 3pth bounce and flex? #1
IndyIan
Veteran Member
Trent Hills, ON
Kioti DK40SE HST
So I picked up an old HD box blade this weekend. I am pretty sure its an older Land Pride MR3584 which specs say weighs 1117lbs. So that's roughly half of what the 3pth is rated for but is by far the heaviest implement I've lifted.
How careful do I have to be when driving around with the box blade on? It seems that the shaft the lift arms attach allow a bit more twist than I would've expected if I start bouncing the scraper up and down by hand when its lifted. Is this part of the design? I see in the service manual the schematic has a part called the "shock absorber". Maybe its doing its job?:confused:
Anyways, the scraper works pretty well both as FEL ballast and in use so far but I've just torn up parts of the driveway to test it out.
Sounds like I don't have a problem!:thumbsup:
2018 Dodge Ram 3500 4x4 Utility Flatbed Truck - HEMI Gas, Gooseneck Hitch, Southern Truck (A51039)
2018 Dodge Ram...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A51039)
2016 KBH...
PALLET OF PIPE CLAMPS (A50854)
PALLET OF PIPE...
2018 Generac MLT6SM-STD3 6kW Towable Light Tower (A49461)
2018 Generac...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2022 John Deere 8RX410 Track Tractor (A50657)
2022 John Deere...
