DK35SE HST
   / DK35SE HST #1
JoeySchmetloff
2013 Kioti DK35SE HST
Changed fluids and filter HST, manual says nothing about bleeding system but workshop manual states: Bleed air from system before starting the engine after any HST related parts, filter, fluid, the system should be bled before starting engine, if started, damage to HST could be damaged.
HOW to bleed HST hydraulics???
   / DK35SE HST #2
Just run it and make sure everything works in the first minutes. Chances are it will self bleed as with 90% of the hydraulic systems.
If not, use some compressed air to prime the system. Basically, wrap a cloth around the nozzle of the air gun and put it on the fill neck so it somewhat seals enough. Then, with the tractor running, give it a couple of small bursts of compressed air to hopefully push fluid up to the hydraulic pumps.
   / DK35SE HST
One other question...drain plug for HST?? under left foot pedal area, near HST filter...I opened main drain plug between rear wheels...drained and replaced transmission filter on R side...did I drain the HST also...or is this a separate drain plug???
2014 UTILITY 53X102 DRY VAN TRAILER (A52141)
2014 UTILITY...
KJ 33'x25' Double Garage Steel Barn Shed (A50121)
KJ 33'x25' Double...
2017 Bobcat E26 Mini Excavator (RIDE AND DRIVE) (A50774)
2017 Bobcat E26...
2025 84in Dual Cylinder Grapple Bucket Skid Steer Attachment (A51691)
2025 84in Dual...
Comfort Chute H Series Hoof Trimming Trailer (A50774)
Comfort Chute H...
