DK35 SE HST Back Hoe
   / DK35 SE HST Back Hoe #1
Dlanierjr
Perry, Ga
Kioti DK35SE HST
I am real close to buying a Woods BH-80X with mechanical thumb backhoe for my 2008 DK35. The 80X is what the dealer recommended for this tractor. Does anyone know if this is a good fit? Should I consider the BH-90X? The Woods hoe seems to have very good reviews which is why I am leaning towards buying one. Does anyone think the Kioti hoes are better than the Woods? Would really like to get some expert opinions before I pull the trigger on 11k. Any information or opinions from someone that has been down this path before would be greatly appreciated.
   / DK35 SE HST Back Hoe #2
I have the 80X on my Kioti 45 it has been great. Bought tractor front end loader ( Woods ) new in 2006. My only regret sometimes I wish I had bought the 90X
NC Redneck that's what I'm afraid of. If the 90X will be fine on my tractor I would rather buy it. I just don't know if the 90X is to big or have requirements like hydraulic pressure and volume that the DK35 cannot produce. After spending 11k I don't want to look back and wish I done something else.
   / DK35 SE HST Back Hoe #4
I believe you will be happy with either model. Break out force is the main reason I want a larger hoe. The 90 should cut a 4 inch root where I can cut it at 3 inches with 80. Digging stumps would be the main difference. In regular digging dont think you would see much difference. And if you are like me probably have a lot of backhoe work to do when you first get it. After that maybe 3 or 4 times per year.
Hope this helps
Scott
   / DK35 SE HST Back Hoe #5
11K WOW! I would get what I had on my DK-35/se/hst and now have on my DK-40/se/hst : the Kioti brand KB- 2485 hoe. It's a LOT cheaper and is an AWESOME hoe. I use it all the time and it's never let me down. I got a manual bolt on thumb, then a bolt on hydraulic thumb, and now have a welded on hydraulic thumb. I really like it and have a special ripper tooth I use in place of the bucket to dig out roots/rocks, etc.
Save yourself about $3K going with OEM.:thumbsup:
   / DK35 SE HST Back Hoe #6
might want to check out rhino. i think they r made in USA and make new holland OEM backhoes and bobcat tractors backhoe. in fact i know of a few tb8 bobcat backhoes that r going for bargain prices at the bobcat dealers. I'm trying to find a tb7 and all i keep finding is tb8 s and they r trying to move them.
   / DK35 SE HST Back Hoe #7
I concur, $11k is mighty steep for a hoe. Look at the Kioti for a lot less $$
   / DK35 SE HST Back Hoe #8
For $11K you could maybe get a used mini-ex. I don't know how they justify prices like that?! Reputation aside that's a whole lot of $$.:confused3:
And I guarantee you, the extra $3K or more, doesn't translate to that much better a hoe in use.
Here is the Kioti specs on the KB-2485:
Specifications
Digging Depth 94.4"
Reach (From center of Swing Pivot) 136.1"
Loading Height (Bucket at 60 degrees) 80.3"
Swing Arc 180°
Transport Height (Maximum) 92.9"
Transport Overhang 50.4"
Bucket Rotation 180°
Stabilizer Spread (Down Position) 68.7"
Stabilizer Spread (Up Position) 46.4"
Shipping Weight (Less Bucket) 1091 lbs
Bucket Digging Force 3,748 lbs
Dipperstick Digging Force 2,205 lbs
Operating Pressure 2,466 psi
Now the specs for the BX-80:
http://www.woodsequipment.com/uploadedFiles/Products/literature/Backhoes Full Line B12083.pdf
Sorry, can't get the Woods data to separate out to specific models from their PDF.
Seek out line by line comparison by printing out their spec page. and Kioti's and compare head to head features.
FWIW, I believe Kioti welds on their replaceable bucket teeth. I cannot find Woods machine weights anywhere?
Kioti's are listed less whatever bucket you choose. I have their 18" and it does a great job.
Hope this helps. I can steer you to where to get a mechanical or hydraulic thumb if you want one.
The hoe is $9300. The mechanical thumb adds $700. Then after Uncle Sam gets his it ends up around $10,700.
   / DK35 SE HST Back Hoe #10
Your Kioti dealer will be able to save you some cash for sure!
2005 Chevrolet Silverado 1500 Pickup Truck, VIN # 1GCEC19V35Z257979 (A51572)
2005 Chevrolet...
2016 VOLVO EC380EL EXCAVATOR (A51246)
2016 VOLVO EC380EL...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
New Lewis Brothers MFG DB2 Poultry Housekeeper (A53472)
New Lewis Brothers...
JOHN DEERE 5075GN LOT NUMBER 127 (A53084)
JOHN DEERE 5075GN...
