DK35 questions
   / DK35 questions #1
woodyacres
SE Michigan
Kioti DK35SE
Hello,
I was looking for some info on the KIOTI website but was unable to find anything on the information I was looking for. I thought I would look to the experts for their advice and knowledge (that's you guys).
1) Do you know what type of engine the DK35 has and how many cylinder's it is?
2) Approximately how many hours can you get on a tank of gas?
3) Is their one or two hydraulic pumps (JD has two so it doesn't rob for power steering)?
4) How accessible is everything for routine maintenance (engine, filters, oil changes, etc.)?
I am probably going to stop in tonight to buy my new DK35, but just has some questions before I finalized. Thanks!
   / DK35 questions #2
1) Engine model 3B183LXM is a 3 cylinder, 111.43 cu in. (1,826cc), normally aspirated diesel with 38HP at 2,600rpms.
2) Couldn't tell ya
3)It looks like there is just one pump at 15.2gpm.
4)My CK20 makes everything easy to get to and maintain, so I bet Kioti used that same process in designing the DK35 but I don't know for sure.
   / DK35 questions #4
woodyacres said:
Hello,
1) Already addressed.
2) A long day. About 10 hours anyway.
3) One
4) Very good. The side panel comes off once you've raised the hood. That give you access to oil filter, oil filler point. The air filter and radiator screen are right in front of you when you raise the hood.
   / DK35 questions #5
Kioti website says the CK35 is a 4 cylinder and the DK is a 3 cylinder. I assumed the CK had the same motor as the DK. I guess not.
   / DK35 questions #6
I read the engine spec's for the CK35 as a three cylinder..
But it is a little smaller than the DK
Engine Model 3A 165LXD
Engine Gross Power 34hp (25.4kw)
Rated Speed 2,600 rpm
No. of Cylinder 3
Fuel Type Diesel
Displacement 100.5 cu.in. (1,647 cc)
   / DK35 questions #7
No. of Cylinder 3
Fuel Type Diesel
It must be a misprint, but they do say 4 cylinders under the specs of the CK35HST but same 100.5 cu in and same model number.
   / DK35 questions
Thanks for all your answers! I am going tonight to sign all the paperwork. SHould be delivered tomorrow!:D
   / DK35 questions #9
That's good to hear. Conrats and Welcome to the Pack!
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
2007 International 4300 Box Truck, VIN # 1HTMMAAL07H360176 (A51572)
2007 International...
2022 CATERPILLAR 272D3 SKID STEER (A51246)
2022 CATERPILLAR...
1999 24DTA pintle hitch trailer (A53472)
1999 24DTA pintle...
LMC LOT NUMBER 141 (A53084)
LMC LOT NUMBER 141...
