DK35 overheating issue
   / DK35 overheating issue #1
ToadHill
Elite Member
Catt county New York
Kioti DK35, Ford 8N, Oliver Cletrac
Problem DK35 overheating, changed fan belt, new thermostat. When releasing pressure cap, fluid flows into resinous but not when cap is on. Will get a new cap this week but this one is only a couple years old. Any other ideas??
   / DK35 overheating issue #2
The reservoir is supposed to catch excess fluid as it heats and expands then allow it to go back to the radiator when it cools. I'd try blowing air then running water through the radiator fins from back to front. You may have dust and weeds built up preventing the transfer of heat.
   / DK35 overheating issue #3
What symptoms of overheating are you seeing. Guages sometime malfunction but if you are saying steam comes from cap when in operation, that doesn't sound good. Might want to try a thermal thermometer or new sending unit. Be very cautious to not overheat more than absolutely necessary for troubleshooting. Diesel engine doesn't tolerate overheating and can be easily destroyed. Blown head gasket is a suspect and usually causes bubbles in radiator when turning engine with starter and idling. Some auto supply stores offer chemical that changes color if exhust gases are present in coolant.
2012 GMC SAVANA BOX TRUCK (A51243)
2012 GMC SAVANA...
New Holland B95 Backhoe (A50490)
New Holland B95...
2022 Adams CLC-1013 Conveyor - New (A52128)
2022 Adams...
2019 CATERPILLAR D6K2 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2017 terex warrior 1800 screener (A50322)
2017 terex warrior...
2001 DITCH WITCH JT1720 DIRECTIONAL DRILL (A51242)
2001 DITCH WITCH...
