DK35 hydraulic fluid light.
   / DK35 hydraulic fluid light. #1
mattman
ElDorado,AR
Kioti DK 35
Tried a search couldn't come up with a hit.
Have yellow hydraulic fluid light coming on after couple hours of loader work. I don't run tractor very hard during loader work. I I use foot throttle. Manual says hydraulic fluid is getting hot. It is full of fluid and filter has less than 100 hours on it. Does anyone have the specs for at what temperature light is supposed to come on? There is two sensors by hydraulic filter figure one measures temperature and the other low pressure like if filter was clogged up?? Wouldn't think filter was clogged or light would come on at cold fluid temps when it would be thicker.
Anyone else run into this? I know the control valve for the loader gets hot to the touch, like can't hold your hand on it.
Going to bush hog here soon it will run constantly for awhile, so if it is going to get hot it will for sure running that long at pto rpm.
   / DK35 hydraulic fluid light. #2
I didn't know a DK35 had an indicator light for the hydraulic fluid getting past a certain temp nor a sensor for low pressure. Hopefully another DK35 owner can help. If you have been brush hogging, maybe the hydro fluid cooler, which is in front of the radiator, is full of grass, chaf, etc.
   / DK35 hydraulic fluid light. #3
Thought all my DK 35 had was a light for the hydraulic filter.
No hydraulic temp. light that I am aware of.
The gear drive DK's do not have a hydro cooler.
   / DK35 hydraulic fluid light. #4
Hydraulic fluid light? Never heard of this... My DK35se does not have anything like that... pictures please.
OK, I stand corrected.. the DK35 has a hydraulic warning lamp. The new series the DK35se does not.
Apparently low pressure or over temp can be indicated by this lamp.
This lamp lights up yellow when certain
problems occur in hydraulic system.
This lamp lights up when the pressure in
hydraulic system drops down below a
specified value due to high oil temperature
(approx. 60 + 5°C) or blocked oil filter
carefully check the hydraulic system.
   / DK35 hydraulic fluid light. #5
This is news to me too. I will look into when I get home as I have used my bush hog for 6 hours at a time (sometimes on very hot days), and never noticed a light. I have seen my engine temp Gg rising which tells me to clear the rad screens ASAP.
My DK35 is a 2004 model and gear drive.
I have the same as was posted for the reason the light comes on. I need to find a better description and how to check which is turning the light on and what to do with it. Hydraulics work just fine, no squealing noises or anything like that. Need to figure it out before I tear something up.
   / DK35 hydraulic fluid light. #7
I have checked my owner's manual, which shows it on the dash map page and in the service manual wiring diagram which shows a "hydronic" light though the owners manual also talks about a blocked hydraulic filter. I have never seen the light come on, not even when turning the key from off to the run position. Not sure if it works or how to test the sensor/relay/light but will look into, later.
   / DK35 hydraulic fluid light. #8
And the next question would be, why did they not see fit to put one on the new DK35se model?
   / DK35 hydraulic fluid light. #9
Is it possible it is fit "for but not with" ? It may be a generic dash cluster but only used in certain models? Not sure when, but probably next time I pull it in for service, I will take a closer look at this.
   / DK35 hydraulic fluid light. #10
On the old (non SE) DKs there are two sensors on the hydro filter bracket: pressure and temperature. The hydro pump sucks oil through the filter so a clogged filter will cause low pressure at the filter output. High temperature is self-explanatory. Either condition will turn on the instrument panel light. You may have a bad sensor. You may have crud in the fluid that eventually plugs the filter after running for a period but then drops off when the tractor is not running. You could have a defective filter. You may actually be overheating the hydro fluid. Normally, both switches should be open circuit. You can determine which switch is closing by pulling the connectors (one at a time) to see which one turns off the light. You can measure the temp with a non-contact thermometer at the oil filter. The manual is cryptic but it looks like the temp switch is supposed to close at 53 C and the pressure switch at 500mm (+-30) vacuum. Or you could just try a new filter if you haven't changed it lately.
1999 International 4700 Dump Truck, VIN # 1HTSCAAN3XH660516 (A51572)
1999 International...
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A53472)
2017 KINZE...
2014 Nissan Rogue Select SUV (A51694)
2014 Nissan Rogue...
2 Disc Heavy Duty Bottom Plow (A51573)
2 Disc Heavy Duty...
2000 Wabash National 53ft T/A Dry Van Trailer (A51692)
2000 Wabash...
