DK35 Block heater
   / DK35 Block heater #1
NIXON
Veteran Member
West Sunbury ,Pa.
L3130 hst
Went over to my local Kioti dealer today to look at the DK 35 .
To say the least I was impressed . Both by the dealer and the DK35. But, one thing that does trouble me a bit is ,he said there was no way to put a block heater in the engine . I have got to take his word on this ,as he was very forthright with all my questions . Just seemed a bit strange. Especially when considering it was designed in Korea . Not exactly a place I'd want to go for a winter vacation /forums/images/graemlins/smile.gif To be fair , He did say as long as it was garage/shed kept it would be fine .
The look on his face when I told him that it would be used to build it's Shed was funny /forums/images/graemlins/smile.gif So, to make a long story short..... Anyone fitted a block heater to their DK ??
All the best, John
   / DK35 Block heater #2
If a block heater can't be installed, you might want to look into a generic lower radiator hose heater.
Jerry
   / DK35 Block heater
Jerry,
Where would I find one should the need arise ? Thanks, John
   / DK35 Block heater #4
You will not need Block Heater on a DK 35. iI sold a lot of
them ann NEVER have a complant about cold weather starting.
Temp been below 0 here
   / DK35 Block heater
tractor hill
I'll take you at your word . My concern was with diesels in general , I know my F250 6.0 psd will start at -10 or less . But it sure is cranky . It doesn't seem to like COLD starts at all . Plugged in She seems fine . So my reasoning was the DK might be the same. I just thought that oil that wasn't at ambient temp (30 or below) wouldn't be as good as something warmer . I know it's "just a tractor" but to me it's still something I'd like to be as easy on as possible . Thanks , John
   / DK35 Block heater #7
John,
The block heater is something I never checked into so I can't help you there.
My DK does start OK in the cold when you let the glow plugs cycle through.
But like your Ford it does put up a ruckus when cold.
   / DK35 Block heater #8
My 35 came with one installed. You will need it in a shed at -20. I did. bcs
   / DK35 Block heater
justaplain...
Now I find that interesting to say the least . Any chance of a picture ??? I'd sure feel better about cold starts with a block heater . All the best, John
   / DK35 Block heater #10
I haven't had any problems starting my DK 45 with about a 20 second cycle of the glow plugs, and that was in below zero weather (which is rare in this part of Kentucky, but we had several mornings like that this winter).
I would agree with the earlier comments that you could fit a generic lower radiator hose heater and achieve basically the same effect as a block heater. For extremely cold temps, you could also go with the magnetic heaters on the oil pan and a battery blanket for the battery (obviously) and then I'm sure the tractor could start in virtually any weather.
I do find it curious that one dealer says that block heaters can't be installed and someone else has a tractor with a block heater on it (from the factory, I guess).
Take it Easy
Tim Gray
2012 Freightliner Cascadia 113 Semi (A50514)
2012 Freightliner...
2018 CAT 320GC Excavator (A47384)
2018 CAT 320GC...
UNUSED AGT QUICK ATTACH DROP HAMMER (A51244)
UNUSED AGT QUICK...
JOHN DEERE 437E KNUCKLE BOOM LOADER (A51242)
JOHN DEERE 437E...
2005 Dodge Caravan Van (A51694)
2005 Dodge Caravan...
