DK35 4 wheel drive
   / DK35 4 wheel drive #1
rawsum
Kioti dk35
DK 35 4 wheel drive stopped working
   / DK35 4 wheel drive #2
Could be lots of different things.
From as simple as linkage adjustment or repair,
to drive shaft repair.
Or transmission output or front diff or axle.
Ive checked driveshaft..replaced 4 wheel drive push button and fuses. I believe the problem is between the switch and the drive shaft
   / DK35 4 wheel drive #4
Then just of the top of my head,
if you have a push button engagement, you must have an electric solenoid that will engage either a wet clutch or a dog clutch.
Without a service manual it's hard to say what is going on.
Roughly if you can find the solenoid and see if it is getting power, if it is can you feel it engage (clunk) when switched on.
Thank you. I will check that out and let you know what I find.
   / DK35 4 wheel drive #6
if you have a push button engagement, you must have an electric solenoid that will engage either a wet clutch or a dog clutch. doodle cricket
How to handle when the power supply does not work?
   / DK35 4 wheel drive #7
Check fuses and wiring.
2017 FORD F-550 XL SERVICE TRUCK (A51406)
2017 FORD F-550 XL...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
FRONTIER SA21G LOT NUMBER 145 (A53084)
FRONTIER SA21G LOT...
New Land Honor Heavy Duty Plate Compactor (A53002)
New Land Honor...
2018 Gatormade 20+5 Gooseneck Trailer (A53472)
2018 Gatormade...
2018 TAKEUCHI TL8 SKID STEER (A51246)
2018 TAKEUCHI TL8...
