DK series width
   / DK series width #1
Ratrace
Kioti ck3510se
I'm looking at getting a DK4210SE cab. The minimum width according to Kioti is 49.2 to the center of the front and rear tire. That's with AG tires and adjustable rims. I can't find anything on what the width is with Industrial tires. What is the minimum width? Can the rims be adjusted on them?
Will this tractor fit through a standard 8' garage door?
   / DK series width #2
No problem. I think it is about 72" wide. My 6 foot brush cutter is about an 1/2 inch wider on each side and I think it is 73 or 74. I haul it on a trailer that is 6.5 feet wide.
   / DK series width
Ok thanks. I need the tractor to be narrow for tight trails so I will go with AG tires. The tractor is 62.8" wide with those. 72" is way too wide for my tiller too.
   / DK series width #4
That sounds like the width of a CK series. I used to have one and it was a bit over 60" with R4 tires. I would think a DK that width would be unstable on hills.
   / DK series width
I have flat land so all good.
   / DK series width #6
I have a DK5310SE Cab rear tires are stock 14.9x24, the rear tires are adjustable, just switch the side of the tractor they are on, this keeps the tread going in the correct position. In the narrow position it is about 65” wide (use with the. 66” bucket. In the wide position it is about 70” (use with the 72” bucket)
Land Honor Portable Screener (A50514)
Land Honor...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2007 INTERNATIONAL 4200 SBA 4X2 DUMP TRUCK (A51243)
2007 INTERNATIONAL...
UNUSED CFG Industrial MX15RX Mini Excavator (A47384)
UNUSED CFG...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A51222)
2018 INTERNATIONAL...
New Mahindra 8100 CLGC Euro Loader (A50774)
New Mahindra 8100...
