MotorSeven
Elite Member
While baling 75 4x4 rolls today I smelled raw fuel. The last time this happened I found a cracked fuel bowl. This time it was much more interesting. I raised the hood and saw fuel dripping off the bottom right side of the fuel tank. The source was the two return fuel lines, one from the filter and the other from the injector pump back to the tank. What was causing the leak was the metal shroud that holds the fuel tank in place. It has a small window cut to allow the two return line nipples that are molded into the tank to stick through. Either the tank has mover up or the shroud has moved down cutting into both nipples(ouch). The return lines are circled in red:
A close up, hard to tell, but the metal is pushing down on the nipples:
THis is what the return line looked like:
