DK hst filter
   / DK hst filter #1
chuck172
Platinum Member
N.E, Pa.
Kioti DK40SEH, Ford 4500TLB, Ford 8n
For those with the DK models that have chosen to substitute the HST filter (Kioti T4125-38021) with the Hitachi T412538021 , or Donaldson P573481. How'd you make out?
Any problems or second thoughts?
   / DK hst filter #2
I've been using the Donaldson P573481 on both of my DK45se Hst tractors for about 100 hrs each now with no troubles. You would never know the difference at this point.
I've kept my old used Kioti filter, so when I change this Donaldson out, I will cut both used filters in half, then present photos here on the forum comparing the two. They do look slightly different internally when looking into the filter, but the ratings are the same, both with an 11 micron synthetic media, rated for the higher pressure.
Both: 87x154mm Thread: M45 x 2
Both: Gasket OD: 61mm ID:54mm
All Cross References I can find for the Kioti T4125-38021:
(Mfg.) Hitachi T412538021
Donaldson P573481
Fleetguard HF35519
Baldwin BT9464
Caterpillar 518670
   / DK hst filter
I assume that this baldwin is the same as the others: https://www.grainger.com/product/49T326?cm_mmc=PPC:+Google+PLA&s_kwcid=AL!2966!3!50916726237!!!g!82496520357!&ef_id=WnXORwAAAcQGyHLO:20180203145919:s&kwid=productads-adid^50916726237-device^c-plaid^82496520357-sku^49T326-adType^PLA
1999 John Deere 4300 (A50123)
1999 John Deere...
2022 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2022 CHEVROLET...
2013 International WorkStar 7400 4x4 Altec DMA71 Insulated Digger Derrick Truck (A51692)
2013 International...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
