DK 55 loader options/hydr. pump
   / DK 55 loader options/hydr. pump #1
gmol
Vermont
Kioti DK 55-New Holland EC-35
I know I ttried to ask before but! Any one know of any other loader options for DK 55 other than Woods and Kioti. Also any way to speed up my pump. Loader is sleepily sloooooowwwww. Everything specs out on hydraulic system. Any thoughts and no bashing, I love this tractor. Just trying to speed things up
   / DK 55 loader options/hydr. pump #2
Rhino, and Bush Hog both make loaders for this model. Im sure others do as well.
   / DK 55 loader options/hydr. pump #3
You may find many makers of backhoes that can fabricate one for that model, but none of them are going to be any faster than the hydro pump will allow. You might investigate to see if you can get a faster output (flow) rate which is the only way you're going to get a faster loader.
John
   / DK 55 loader options/hydr. pump #4
There are two ways to speed a loader up. One way is to install a pump with thicker gears. The other way is to use smaller diameter cylinders. If you change the pump the amount that you can lift will not be affected, but with smaller cylinders the load will be decreased.
2016 Ford Explorer...
UNUSED JCT SKID STEER QUICK ATTACH AUGER SET (A51244)
UNUSED JCT SKID...
(4) Stand Alone Texas Panels (A50515)
(4) Stand Alone...
2019 Club Car Carryall 1700 4x4 Diesel Utility Cart (A48082)
2019 Club Car...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
Richie Water Master 1200 Trough (A50774)
Richie Water...
