DK 55 Front axle oil change
   / DK 55 Front axle oil change #1
qwerty123
Pittsburgh PA
Kioti DK55, Case International 245
I'm about to perform the 50 hr. oil change on the front axle of my DK55. The manual indicates that I should replace the oil with either SAE 80 or 90 weight oil. No other specifications are given. So does this mean I can use a either GL-4 or GL-5 gear lube? From what I read on the Oil, Fuels and Lubricants forum, certain additives in GL-5 type gear oil are hard yellow metals. I have no idea if the front axle contains yellow metals.
   / DK 55 Front axle oil change #2
On my CK25HST, I just used 80/90 gear oil from my local Co-Op... Didn't know their we're classes of gear oil... But after reading this, it appears it was GL-5 approved. Here's a link for your FYI:
http://www.rrcoop.com/products.php
   / DK 55 Front axle oil change #3
Thanks for all of the replies.
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
2017 FORD F-550 XL SERVICE TRUCK (A51406)
2017 FORD F-550 XL...
2016 Sure-Trac 20 Ton Pintle Trailer, VIN # 5JW2U2522G1121114 (A51572)
2016 Sure-Trac 20...
JOHN DEERE 661R LOT NUMBER 106 (A53084)
JOHN DEERE 661R...
