DK 45 jerking when clutch released.
   / DK 45 jerking when clutch released. #1
Brian m
Barrie ONT CANADA
2002 kubota L35
Hello.
I purchased a DK45 with loader.
with the loader attached and releasing the clutch it is jerking forward. With the loader removed it is smooth. And ideas ?
Hello again. This only happens when my loader is attached. With loader removed it is smooth.
   / DK 45 jerking when clutch released. #3
My guess is, it isn't the loader causing it, it's the extra weight of the loader. What about when you try to pull a heavy trailer or some other heavy object?
This all assuming the clutch pedal is smooth in operation.
It sounds like that tractor has had the clutch slipped a lot in it's life and will need replaced.
SR
It has 450 hours on it.
I will remove the loader and pull my car trailer loaded. And report back
   / DK 45 jerking when clutch released. #5
Also, check if all the bolts on the bell housing and loader mounts are tight. I wonder if the bell housing bolts are loose and the extra weight of the loader moves things around and makes the clutch act weird.
Ok. FYI. Only dose this in forward
   / DK 45 jerking when clutch released. #7
The centre of gravity changes With the loader attached. If you’re driving fast the tractor becomes bouncy, even worse with a loaded bucket. Are you driving in high gear high rpms when this happens? Oh…and is it gear or HST?
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2011 JOHN DEERE 310SJ BACKHOE (A51242)
2011 JOHN DEERE...
UNUSED CFG Industrial QK16R Mini Excavator (A47384)
UNUSED CFG...
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
2017 CHALLENGER MT465E TRACTOR (A51406)
2017 CHALLENGER...
2018 CATERPILLAR 299D2 SKID STEER (A51242)
2018 CATERPILLAR...
