DK-45 Clutch adjustment
   / DK-45 Clutch adjustment #1
Dr_K
NW Indiana
Kioti DK-45
I have a DK-45 with 400 hours, and the clutch is out of adjustment. The manual is of little help. I did shorten the adjusting rod by about 1/2 an inch, & that helped, but it is still difficult to engage the forward-reverse lever without grinding.
Should I shorten the adjusment rod more? It barely went back together on the top end after the last adjustment adjustment. It would have been nice if they had made it as easy to adjust as the brake lever!
Is a trip to the dealer is an store for me? Any advice would be greatly appreciated. Thanks!
   / DK-45 Clutch adjustment #2
Is it just the shuttle that is grinding or does the transmission also grind while shifting. It shounds to me like the syncros in the shuttle are worn.
   / DK-45 Clutch adjustment #3
If a manual tranny is grinding with clutch depressed, shortening the freeplay would only worsen the condition if it were a clutch adjust issue- it sounds like tranny synchro/fork problem. Shortening the freeplay decreases the amount of disengagement. If you tightened up the slack and it were better then your onto a clutch issue. Clutches as they wear have less freeplay at the pedal and you would need to add some freeplay via loosening adjustment. I'm not sure if Kiotis have a pilot bearing or bushing or bearing in the back of the crank supporting tranny input shaft- if it were seized you could get clash issues. Happy hunting!
Mark H
ASE Certified Master Automobile Technician
ASE Certified Automobile Advanced Engine Performance
Tractor Junkie
Yes, it is just the shuttle. The gear shifter works fine.
Thanks for the reply.
Jerry K.
Thanks, Mark. I lengthemed the clutch adj. rod this morning & that helped a lot. But, I have to be at a dead stop to shift from forward to reverse or back without grinding. If I start in neutral and then shift into forward or reverse, then I get a slight grind. Maybe oil on the clutch plate? Maybe a broken finger loose in there?
In any event, I'm O.K. for now, but wonder if I have clutch rebuild coming one day?
Thanks for the reply!
Jerry K.
   / DK-45 Clutch adjustment #6
Its your syncros in the shuttle. More than likely they need shimed. Does your shuttle pop out of gear ever? Your clutch is more than likely not the problem but the syncros in the shutte.
   / DK-45 Clutch adjustment #7
I think Jon's right, my knowledge applies to generic automobile manual tranny clutches---I haven't yet had the fun of tearing into a shuttle tractor. My CK30HST order is a couple weeks to a month off. So from what I understand the shuttle is in front of or behind the main gearbox?
"I cut it three times and it's still too short"
Thanks, Jon! For now, I am shifting o.k. as long as I come to a full stop. If I start up in neutral & then shift into forward or reverse, I really have to baby it to keep from grinding. If I shift directly from forward to reverse or back at a full stop, it is pretty smooth. I guess that is a small price to pay to avoid a repair that involves that dreaded phrase: "break it in two."
I assume that shimming the synchros would involve that.
Thanks again,
Jerry K.
JOHN DEERE 560M LOT NUMBER 37 (A53084)
JOHN DEERE 560M...
2014 Dodge Charger (A52377)
2014 Dodge Charger...
New Wolverine Skid Steer 3pt Hitch Quick Connect (A53002)
New Wolverine Skid...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
