DIY Snow Plow on a Cat 262D Skid Steer: Leaking flat connector.
   / DIY Snow Plow on a Cat 262D Skid Steer: Leaking flat connector. #1
lankyyankee
Howdy Forum,
I've been dealing with a nagging problem I just can't seem to solve.
Background: I recently got a great deal on an old 7 foot Western pick up truck snow plow that I've mounted to a quick attachment plate that I'm using on my Cat 262D skid steer. Like most pickup truck plows, it has two single acting hydraulic cylinders. They are made for ~5 GPM not the 25GPM that comes from my tractor, so I made some 1/16th inch restrictors (pictured below) and also installed a cross relief valve for impact protection.
Here is a picture of the restrictors I made prior to drilling the 1/16th inch holes. The dimples are to prevent the aluminum from backing out.
efYRoYAZWQVIks6HBKtaPIMNmQLF0eOpVeTAqmbUIqGxIQULrL  K1-0UakqYha_hhwGX1Isj4N6s2vrGoYFYTmac13TMpqpnDoe6ak_f  k1cdkcatV0jhfXcygBl3GOzpYJjRO55xOEJfZoIYEO0xGXseAT-Yu3ZNGhxoBKVEPFxrD6DgDXj_arYPhnJCMqSO0zQRd7G0jaBj5  SDlFIGsgJy4edw8hyHUbQtgGzXq9rZXUSSv7fbm-Secj1fhufVT4uVYx4RMJCD0fjX3X7waESih5moNmwT0qGsaOFf  ge19xHrx7GhoME2lJG2gETR1gph1-HfxnDFi5BGfEwiVjqTtIHJF019JqaW7Dbsz1nemXeED3vESvBy  pC92iKZ1otR-wuyQrN87HFec3qHVaNQ28DtNOe1ke4izoBqAO8tHEbrxyQsd_c  MMmbZf_HLxDqqXuhngTkXjJFzZZjNk_6NfVZ6dmsDDGv5Ywy5p  kvWgvxBbu_kwZUfi77UToqE3w0p5YwetzLdpAd9oZnuVq93KTI  KYTVn0_ytyjs20X6CJSkwRLr-TKHFIfO4Ccm_KBcfhrT2AYvQn9Yr9TY0fr4bZoViXaoDtLMzgS  _4cEUwUP5AGsHhWTNc=w600-h558-no
Basically, I followed this guy's work:
http://rodnh.byethost12.com/bobcat/bobcatplow.htm?i=1
My hydraulics layout is similar to the above website:
My Cross relief valve:
1/2 NPT 3 GPM 15-3 PSI HYD CUSHION VALVE
The problem: The blade moves left and right as expected, when I roll the hydraulic thumb switch on the cat forward and aft, but the problem is, I can't for the life of me, get the bottom flat connector to stop leaking hydraulic fluid. I've swapped out both FEM flat connectors on the plow and on the tractor but that didn't help. I connected the plow to my neighbors Mustang skid steer and it leaks on his flat connectors too. Since it's leaking on both tractors, neither of which leak with other attachments, this leads me to believe it's an issue with the plow hydraulics. I must be missing something in my design. Any ideas?
Much Appreciated!
-LY
Here's a video of the offending connector. Not a huge leak ,but enough to make a mess over an hour's worth of plowing.
YrbvEYAPwMCe2rKD6WznyxRc8zKvE1C1tNX6JSFaUCEDvuNR3b  PDL6c0s1m2G1WSFjiU9NLJjsOje_9UiwBgOLK-8ovz8ZFutxiIbpakJgsmSqmKA8_H4gkzOAH3WVQUzcrI8xpa5C  1tOkKruKRrTsXC8H2B917jd1hg_pf_S9wtpMp8MRu3vwtCFpPh-fhAmRZF1dTP-_-U5qLeJ-F51oD7bK_OhnUXHBRrYGchzU7G2aocr_sc6LKCxjOQN7X6V65T  iwP18clUiqJSOXY5OSGKPf1KJDafB2VnUuIrsOq9IHEZHEL-PkqEB8nGGCs3ucPwtS0zcBVaoAYLHwXAejKf9mmQZx1LY3q8N3  WrozIz02YmknlWsJW3QHOJbEWCMPWAcS6jwnhQ0sKGo4G1XcJW  VuwCGUCV1w8Kqd3e1Rt7HlEDVHh5DcISjgl-gIf_1Vo4WBs-ytZXUoX-5tWLOhE7Kd2_leks_Q8j5xE4_t5dJP6nviFPslojcHbf2l4lQj  gmTYY6FJdKg-qZWjrdCTmpx7BRCjw2rKSDu7MkKz5ms35I0ZT2BmRmP6hdd_xM  jRKb5ogpo5UEKEsizjnWIHEr2ouhT6ePn-YhW7YzrhldcKfFmZiO=w1800-h981-no
   / DIY Snow Plow on a Cat 262D Skid Steer: Leaking flat connector. #2
Do other attachments leak on that port?
Can't say for sure, because I don't have another attachment that requires the aux hydraulics. But like I mentioned, I took the plow to my neighbors and it leaked on his Mustang skidder too. He runs other brush cutter attachments and they don't leak, so I assume it's the plow.
Plus, I've replaced both ends of the coupler on the tractor and on the plow side. Since they are new couplers, I'm wondering if I'm not in some over-pressure situation?
   / DIY Snow Plow on a Cat 262D Skid Steer: Leaking flat connector. #4
Shouldn't be. You can buy flow restrictors, both fixed and adjustable like seen in you link at Northern Tool or at a Parker Hydraulic store. Are you sure that the flat face couplers on the skidsteer and the plow are exactly the same? There are some flat faced connectors that are just a bit different. I've also found that there are some manufacturers that don't work well together. I've had good luck with Faster and Parker. I've attached literature from Parker for their FEM and FEC connectors.
  • Skid steer hydraulic coupler.pdf
I ran through my setup with the local Cat dealer. They were very helpful! Todd, they came the same consensus regarding matching connectors as you suggested above. Even though it's the proper FEM connector on the plow side, it isn't a Cat connector. So I'm going to try matching brands. If it works, I'll mic the two offending male ends and report if there is a significant difference in measurements.
   / DIY Snow Plow on a Cat 262D Skid Steer: Leaking flat connector. #6
I had an issue with an FF series connector not working with the FEM series. Hope you get it worked out.
RESOLVED! While the Fleet Farm FEM connectors fit the CAT skid steer, it was not the right connector. After installing CAT brand flat connectors, I have no more leaks! Lesson learned, I have to go with cat brand connectors, I mic'ed the male flat connectors from the different brands and they are slightly different diameters and taper.
The new CAT brand connectors also play well with my neighbors Mustang skidder, so I don't think this fitment is limited to only Cat machines.
Thanks ya'll.
-LY
2Jiw571KjXt2aylqDKarGvWxR-SJiV2nGaDktMlsQnoLmzSGdbk9f7ca6CKfcq641WqJpHZwnq8jaT-KAB1KLFpPK7mHGDPAaLYkKatRt3dgAODCWMIdZ26rQ6Bg9zlprarCXrJ2ghf6hstp2-p1Hd_wDVvLRdY6QP0PKajg09Io-sk0Xv3R3qkjIqHWRRIPLBQpw-lvoJw0VNchKg3vjsumiE4fvFD2oACt8lwbYBvx4gNLtJwzBwREUuolBIT11TxZW_CknxjJEM_nNqaby0L2LwijqaekCEXa8h882rTuO9MdTPgZYzHHa_F5SNvoJxxmh3uWWcfxzsyIH3nWFv9G6iQPbW-6OhcQW1KqywzSyyv2nxGLHtCid8ujgMT0TOBsJHp9Tvrd7a7OMde9a9EQa1YbvsiICAmF58XDJw9zww_I_hKGD2AfrsCouTP9GR0vDcqD7XuKjrr_n47tcIBlHxQyas8DFWAgagn_F-AIquZT3BausuvohlrztvFXpERC3J5mkZC7KzMwGahmkQSuxUraNGFaXY-fXPTN3VZjDeElMQZH0V0ngKb-bkJuSA8G-kqDL9_p5wYi4k9gTZYQ-HIujUMK9ToaZ-mio_F5KDrlG5Vg=w1200-h675-no
iKSJsIBNao69nUBKhgbeGZzqBPcDLG4Ij5grpOfS__8xSxwUt2sdKh73jOuhIwmP7c1VyMGWF3n3JxvcBkB-Sk69GF8_yMtkWBeTMrchhgmdYJZzKZUfsKnoQH9rcPQKiU0EjoRBTKYTWNEbABd4_1jHGnh83GmKPFNBos7sV6mNUtDrfyQgcPqL-cbR_CXH-RLFHqQYhZc1KbA27oATdNjF2U66Z4I6CwHaln9IC8oOJSIMT2x1p8sa1iPq_GJqLbs9W28zFyKA4Uh4bdeZUivF2xHLMJxullILeDhJJ9cEHRrPYJ4hiFtAtweel1Bm9__cvGNMt-IILsYPJX1TMmHrNwo8PS2subkvrsuVb6XMjgavPTBY_XZr4GMD0KD0gqfWw7mxty9_d4xaXR9TIcWTpg1VA3ZS6aPEX9uoJBjk3M-U4CdiDSiiokcYhSjV7vlUR82_RvJ4-H8wICh14Xn6eWXN0Iz9ObjWIJdme4_MyTfih0Qmc2qTv8TXynD0fMrXfbOUSJ_Tv2d8Y3nxUkVPmUXmQvQZCVETq9NW3wsklUNiGNzL_563aavveIpu0dVxJAm6lb7Dd1VnkYCyFdAmLt694w-pJjJlw9gjh4xNFHkUINOV=w1600-h900-no
   / DIY Snow Plow on a Cat 262D Skid Steer: Leaking flat connector. #8
I bet Parker or Faster connectors would work too. The cheap ones from places such as TSC and Fleet Farm are just that, cheap.
Glad you got it working. Nice unit.
40' CONTAINER (A51244)
(APPROX 50) 2" X 2" X 97" TUBING (A51247)
(APPROX 50) 2" X...
2015 Jeep Wrangler Unlimited Sport 4x4 SUV (A51694)
2015 Jeep Wrangler...
UNUSED WOLVERINE 66" BOLT ON PALLET FORKS (A51248)
UNUSED WOLVERINE...
