DIY Loader Bucket Plans
   / DIY Loader Bucket Plans #1
sansei
Does anyone know of a website, or other source of plans for a "Build it Yourself" bucket, for a compact tractor front loader. They must be out there! I have a Massey Ferguson Model 232 front loader, and I need 60" width. Thank you
   / DIY Loader Bucket Plans #2
Sansei
I have built a couple of buckets for my skid steer. It was really easy. I just looked at another bucket used an angle finder to get the right angle. Then I told the local metal shop I wanted a sheet of X gauge steel broke at that angle. I cut some steel for the sides and welded them on and reinforced the edges. Then I welded up the attachment plates and the cutting bar which was a beveled grader blade that I picked up for 17 bucks at the scrap yard. Add paint and I was done. The main project took about a day to do. I also needed some time to find parts and paint. Cost was about $125 I think.
Even easier was the sifting bucket I built. For that all I had to do was make a bucket frame with the cutting bar and weld in rods. It’s not fancy but I bet it works like the fancy ones.
Sorry I didn't answer you question.
Good luck
Eric
44507 (A51692)
44507 (A51692)
2006 GAYLEAN  130BBL (A52472)
2006 GAYLEAN...
10X12 PUMP (A52472)
10X12 PUMP (A52472)
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
2009 Ford Flex SE SUV (A50324)
2009 Ford Flex SE...
