DIY Cultipacker
   / DIY Cultipacker #1
LeadPoison
Platinum Member
Kubota M4900
I am thinking pipe and concrete as the main guts of it. I thought about getting some 2" pipe and welding some rebar around it to it to make a internal frame. I would then insert that into a much larger pipe. Fill with concrete. Then take some heavy rod and insert it into each 2" pipe end. Then bend it around and weld the two for a tow point.
I will be using it for about 8 acres of food plots twice a year. I will be using the Kubota M4900 to pull it. I also plan on building a drag out of a good sized tree trunk and attaching multiple tires behind it.
Thoughts.
   / DIY Cultipacker #2
They are not that expensive. I bought two wing units, four foot sections for a hundred bucks each. (with a couple spare wheels ) I can pull both offset which covers seven feet or one with the garden tractor for small areas. Works real well for me.
   / DIY Cultipacker #3
Hmmm, my 4" axle brillion was $200 used turnkey, and I believe the pointed wheels help break the up the large clods, what you are describing is a cement roller...just guessing but maybe that would push the clods it the soft, tilled dirt underneath. Could you use 18" corrugated steel culvert for the outside?
   / DIY Cultipacker #4
this?
   / DIY Cultipacker
Yep that's it. The corrugated pipe would work well. Basically I just want to press seed firmly into the ground. Good soil to seed contact. I will be breaking up the dirt clods with the tires.
2022 Club Car...
1988 23ft Center Console Fishing Boat with 25ft T/A Boat Trailer (A48082)
1988 23ft Center...
1994 Toyota 6000lbs 2 Stage Forklift (A51039)
1994 Toyota...
WITTIG VACUUM PUMP (A50854)
WITTIG VACUUM PUMP...
2018 Chevrolet Impala Sedan (A48082)
2018 Chevrolet...
2005 International 8600 Hydro Vac Truck (A50860)
2005 International...
