DIY culitpacker
   / DIY culitpacker #1
RancherSam
Hays County, TX
Case IH JX95 4x4
anyone here built a cultipacker to roll behind their grain drill?
I'm thinking of welding together metal barrels, filling them with water, and connecting them through bearings to a hitch to the back of my ancient john deere fb grain drill. Any opinions on this?
   / DIY culitpacker #2
Most of the farmers around here use rubber tire packers. Basically just a lot of old tires (all the same size) on a pipe. Have not seen one up close enough to know if there are bearings etc. being used but you can see the tires wobble a little when they are going down the road so I think they are just sitting on a pipe. Also I would imagine they are filled with something to make them heavy.
Charles
BUSH HOG 3308R-2 LOT NUMBER 118 (A53084)
BUSH HOG 3308R-2...
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A52748)
2012 Freightliner...
2023 JOHN DEERE 8R370 LOT NUMBER 220 (A53084)
2023 JOHN DEERE...
2008 Volkswagen Passat Sedan (A51694)
2008 Volkswagen...
Pull-Behind Smooth Drum Ballast Roller (A51691)
Pull-Behind Smooth...
