DIY Carryall question
   / DIY Carryall question #1
HP942
Poplar Bluff, MO
LS XJ2025H
I recently was given a golf cart utility bed. I thought it would make a great starting point for a carryall for my compact tractor. I need to use some angle iron to weld up a frame like a factory carryall. Does anyone know what size the factory ones are? I’m assuming 2” angle by 1/4” thick. TIA
   / DIY Carryall question #2
That should work fine. It really dosnt matter what size they come from the factory. Mine is 2x3x5/16 square tube because that's what I had.
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
WITTIG VACUUM PUMP (A50854)
WITTIG VACUUM PUMP...
C13 MOTOR (A50854)
C13 MOTOR (A50854)
Grady-White 17ft Fishing Boat with T/A Boat Trailer (A50324)
Grady-White 17ft...
2015 PETERBILT 367 HOT OIL (A50854)
2015 PETERBILT 367...
2020 KUBOTA SSV75 WHEELED SKID STEER (A51242)
2020 KUBOTA SSV75...
