DIY Bike Chain .... Bolt Cutters vs. Chain
   / DIY Bike Chain .... Bolt Cutters vs. Chain #1
Teleological
Gainesville
None
What grade and thickness of chain would you recommend for making a bike chain that is resistant to bolt cutters? I'm just going to go all out and say assume that the thief has a pair of 48-inch hardened bolt cutters.
So what grade and thickness chain would you trust to defeat a pair of 48-inch bolt cutters?
I checked my local hardware stores and I don't think they stock any grade 70 chain ... only grade 40 at the most, and all are less than half an inch thick. Will those do the trick?
   / DIY Bike Chain .... Bolt Cutters vs. Chain #2
Bolt cutters may have some difficulty with certain chains, but no chain or cable will last a minute when attacked with a simple battery-powered grinder. I'd think in terms of a chain or cable plus a loud alarm?
   / DIY Bike Chain .... Bolt Cutters vs. Chain #3
Welcome to TBN. I agree with chim. You might find chain that is somewhat resistant to bolt cutters but then some other area will become the "weakest link". I would also suggest some kind of alarm or finding a more secure location for the bike. Besides - I doubt a truly HD chain would function well on the bike.
   / DIY Bike Chain .... Bolt Cutters vs. Chain #4
My solution in college was buying a $10 ratty looking bike that no one would think of stealing and securing it with a $40 lock and chain.
   / DIY Bike Chain .... Bolt Cutters vs. Chain #5
Hoist chain is much tougher to cut than plain hardware store chain.
   / DIY Bike Chain .... Bolt Cutters vs. Chain #6
take the chain, seat and front wheel with you when you park it ;-)
   / DIY Bike Chain .... Bolt Cutters vs. Chain #7
You need the CarZapper 9000.
Car Zapper 9000 | NOBODY Messes With MY Car
NO its not a joke, its a real product.
A painful involutary muscle contraction should deter a thief.
Or hang an abandoned Wasp nest in the cab, a perceived threat can also be a good deterrent.
   / DIY Bike Chain .... Bolt Cutters vs. Chain #8
Would the wasp nest thing work on a bike?
   / DIY Bike Chain .... Bolt Cutters vs. Chain #9
Carzapper- Now can you see somebody using that at the local Walmart? And then a small child touching the car? Instant lawsuit at the least. Jail time most likely.
   / DIY Bike Chain .... Bolt Cutters vs. Chain #10
aircraft cable and a hardened lock would be better against bolt cutters ... but as stated , a zip rotary tool with blade will make short work of either ....
"all bikes weigh 50 pounds .... a 45 pound bike needs a 5 pound chain and lock , a 5 pound bike needs a 45 pound chain and lock "
HUTCH MASTER 12' OFF SET DISC HARROW (A51247)
HUTCH MASTER 12'...
FRONTIER MG20F LOT NUMBER 80 (A53084)
FRONTIER MG20F LOT...
10' WROUGHT IRON SITE FENCE (A51248)
10' WROUGHT IRON...
UNUSED CFG INDUSTRIAL QH12R EXCAVATOR (A51247)
UNUSED CFG...
2014 Ford Escape SUV (A51694)
2014 Ford Escape...
JOHN DEERE 1705/6700 (A53084)
JOHN DEERE...
