Dixon 3304 ZTR 1999 yr.
   / Dixon 3304 ZTR 1999 yr. #1
bjr
Veteran Member
Eastern WA
Jinma JM354
I'm rebuilding the drives ,replacing bearings and sprockets and chain, on the 30" ZTR and the adjustments are different from the standard transaxle drve information that I have. My lawns going out of control and I need figure out the adjustments procedures to get the cones positioned properly. The information I've got says to bring cones in to just touching. If I do that then there is no lever travel and that need some travel I think. Help. Thanks in advance. bjr
   / Dixon 3304 ZTR 1999 yr. #2
Normally the driven cones just clear the drive cones, Your lever travel comes from the tension rods in the front.
Been quite a while since I set one up, but when we were using the mechanical drive model commercially I was rebuilding about one a week.
Probably PM me with questions if I can help, I seldom check this forum.
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
1999 MadVac 101-D Riding Compact Debris Vacuum (A51691)
1999 MadVac 101-D...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
CATALOG UPDATES LOT NUMBER 5 (A53084)
CATALOG UPDATES...
2024 Greatbear 72in Vibratory Roller Skid Steer Attachment (A51691)
2024 Greatbear...
2022 Ford Explorer SUV (A51694)
2022 Ford Explorer...
