Mrwurm
Veteran Member
- Joined
- Jan 20, 2002
- Messages
- 1,569
- Location
- South East Michigan
- Tractor
- New Holland TC30 Hydro 4x4, Gravely Zero Turn Mower
A septic system is quite the mystery. Most of us know how they work. But, how do you know they are actually working. There really is no way to check.
Home inspectors just run some water down the drain to see if it goes somewhere. They don't actually know where its going, we're all just happy that it goes away.
So, here I am standing in my back yard, looking at the area where my leaching field is located. Yep, looks ok from here. So, why do all the toilets in the house bubble and fill up with foam when the wife runs the wash machine ? A few thoughts come to mind.
1) The vent nearest the wash machine is blocked. But, hey, I've checked a lot of vents over the years. I've never actually found one to be blocked.
2) The septic tank is blocking the flow to the leaching field.
3) The leaching field is clogged.
4) The water table has risen above the level of the leaching field.
Seems, that most of the scenarios involve things that can't be easily assessed. Well, I guess I'll start with the easiest thing and just go ahead and check that vent. Worst case scenario: I'll have to send the wife to check the tank /forums/images/graemlins/smirk.gif
