Divide voltage by 2
   / Divide voltage by 2 #1
stumpfield
Sierra Foothills
2005 MT265B
Anyone know a simple and inexpensive way to divide the output voltage by 2?
I want to charge a 6v battery. My battery charger is 12v only. I don't want to connect 2 6v batteries in series each time I want to charge them because each have different state-of-charge. Any ideas? Thanks.
   / Divide voltage by 2 #2
I think the only real answer is to use a 6 volt charger. Any other scheme will likely only over or undercharge the 6 volt battery. I don't think there is an easy way out....
RavensRoost
   / Divide voltage by 2 #3
seems to me that you could put a resistor in the + line to cause a 6v drop. but i dont know what size.
hmmmm....there is a relationship between volts, amps, and ohms. but i think the amperage output of the charger is not constant.
   / Divide voltage by 2 #4
Randy, you nailed it. You could choose a charging voltage and current and select a resistor to give the 6v battery what it wanted.....for a very brief time until it chatrged up more and now wants less current/higher voltage. I am sure there are "intelligent" devices that will do this. I bet they also cost more than a "dumb" 6 volt charger ;-)
   / Divide voltage by 2 #5
yes, this is correct. If you have an electrical heating element I would connect it in series with the battery and check for the voltage on. 6V battery could be charged by something like 8V (12V is charged by 14.8V in a car).
my $0.02 only
   / Divide voltage by 2 #6
V=IR or P=IE
Voltage (potential) = current * resistance
You've got to get the units right but that's the relationship.
   / Divide voltage by 2 #7
Whenever I try to do something like that, the most expensive part in the arrangement gets ruined. Kinda like a $300 picture tube blowing to protect a 10 cent fuse:eek:.
   / Divide voltage by 2 #8
i've occasionally needed to do something like your talking about, and wired a light socket in series with whatever i'm tryin to burn up, oops, i mean charge or operate: anyway, the more current you want, the bigger the bulb you screw into the socket. actually this does work "fairly" well for a cheap motor speed control on small AC motors. what the heck, light bulbs are cheap, and "maybe" it won't cook the battery or charger.
heehaw
   / Divide voltage by 2 #9
By the time you rig up whatever it will take to drop the voltage in your charger, it would probably be easier to buy a cheap six volt charger.
   / Divide voltage by 2 #10
Highbeam said:
V=IR or P=IE
It was stated in another post, but I'll try to clarify.
The V=IR is true, but the problem is that the I (current) would be changing during the charging. You've all seen that when you hook up the charger to a battery it reads high (10, 15, ?) amps right away, then starts coming down over the next minutes and hours. You would need to have a variable resistor and a volt meter across the battery (or resitor if you like to subtract) to keep the correct voltage for charging.
Much easier to get a charger that has a 6V setting like my 20 year old one does...
2025 JMR 78in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 78in Dual...
Pallet of Miscellaneous Mini Excavator Attachments (A52377)
Pallet of...
2016 GMC 2500HD SERVICE TRUCK (A51406)
2016 GMC 2500HD...
2017 Kawasaki Mule 4010 4x4 Rescue Utility Cart (A53421)
2017 Kawasaki Mule...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
2011 CIRCLE M 32 FOOT GOOSENECK (A53843)
2011 CIRCLE M 32...
