Diverter valve Vs. True third function
   / Diverter valve Vs. True third function #1
HokieMS
Buchanan Va
JD 4005
What does everyone have for their grapple, for one-handed operation? I wouldn't want it controlled by a rear remote, for instance.
I can think of pros and cons for both setups, but would like to hear other opinions.
For instance, Ted at EA says in a video IIRC, that true 3rd function is superior, and he clearly knows a thing or two about implements. But I can think of a handful of scenarios where I would want to feather the 3rd function (ex. hydro post hole digger attached to bucket, trying to pick up specific log with grapple, etc.).
This would be easy to do with a diverter. Push the button, and feather the curl function. I understand that means no curl and 3rd function at the same time. That is not a big deal for me, I'm not on the clock when working on the tractor.
Am I missing something? Is there a big downside to diverters that I don't see?
Eventually I would purchase and install myself. Is there a huge difference in installation between the two?
Mark
Edit: crap. Just realized this should be in the hydraulics forum. Mods, please move if needed.
   / Diverter valve Vs. True third function #2
You can contact a moderator by clicking on the "triangle" icon at the bottom left of your message.
Steve
   / Diverter valve Vs. True third function #3
I'm glad you posted this question Hokie because I am kind of curious as well. I thought I had my heart set on a third function but after some more research I am starting to think maybe a diverter valve would be my best option.
From what I've heard the plumbing to do a diverter is much simplier than a third funct. and I too like the idea of being able to feather the hydraulics. My main thought was if I was to use it for picking up hay bales or planting a tree with a root basket I would be much less likely to crush them.
Interested to hear what some of the people that have diverter valves or third funct. have to say.
   / Diverter valve Vs. True third function #4
A diverter is going to be 2 valves (1 for each line going to the cylinders) you put inline with your existing curl lines. Hit a button & they switch from curl to 3rd function. A fair bit easier than adding another valve into your power beyond loop. You need less hose too as you can put the valves in a convenient spot near the bucket.
You only get curl or 3rd function, not both at the same time as you already noted though. That's probably the biggest drawback.
I keep think about doing it with a 3 way valve instead of a 2 way to add a cylinder to my SSQA levers so my lazy *** doesn't have to get off the tractor to switch from bucket to forks (would need to get off & deal with 3rd function hoses for a grapple I don't yet have though).
   / Diverter valve Vs. True third function #5
My third is electric valve so it is plumbed to the front and controlled by a thumbswitch on the loader joystick.
It is great for what it is used for and that is a grapple. I DON'T like the electric third for hydraulic top link for instance. When I have tried it on that it wasn't as controllable as a lever. So my 4th and 5th remotes are manual levers which would be the same really as using a diverter in that you get the precise control.
IF you are definitely doing a grapple or 4 in 1 bucket for the JD 4005 in your profile I would for sure do the diverter and have a set of hoses made up and plumb one to the front and the other to the back. This gives you flexibility too that you could always make up another set of hoses in the future to run both to the back if more was needed.
Just to be clear your talking about 2 different things, an electric over hydraulic valve & a diverter valve. The diverter just toggles between 2 hoses & uses the normal valve (probably manual, but could be electric over hydraulic as well). An electric over hydraulic valve is just an electrically operated valve (on tractors it will be tied into the power beyond loop). Electric over hydraulic will be a simple on-off valve operated by a switch or button unless you shell out some big bucks for a fancy proportional valve & controls (think modern excavator joysticks)
Some 3rd fuction setups use an electric over hydraulic valve, where you push a button & the cylinder moves (speed is dependent on how fast your engine/pump is going at the time & not really anything else). Using the diverter, you push a button and your normal finely adjustable curl function moves your 3rd function with the speed dependent on how much you push on the curl lever.
   / Diverter valve Vs. True third function #6
I definitely prefer the solenoid diverter for things like grapples - here's the one I bought, it runs about $170.
Scorpion Technologies LTD. - S-Series
Either call them (you'll probably talk to Eden, she's really nice) or ask Brian at Fitrite (member here) it's about the same price either way... Steve
   / Diverter valve Vs. True third function #7
The true 3rd function valve is an independent valve that is controlled by a switch and provides full flow to the attachment. It usually has no relief.
Some people like to associate the 3rd function with the grapple/loader, but it is just a valve that can be added anywhere before the last valve which is the 3pt.
The diverter valve is an add on to the curl circuit that lets you use a switch to route the curl fluid to control a grapple or the bucket curl. You can feather the grapple or bucket curl.
You normally can not use any hyd past the valve you are using unless you only use half lever, and that will let half of the fluid downstream for other hyd operation.
The diverter valves run as low as $95 from Baileynet.com
3rd function about $135, and subplate about $36
Let me correct my statement above. You can get hyd flow through the subplate OUT port, but is is the fluid from the cyl or motor you are controlling. It might not be the flow and pressure you like.
Keep in mind that a subplate valve is plumbed in series and the OUT port connects to the next valve. So it will affect the hyd action downstream.
Which is better? You know the situation you want, so it is your choice. .
   / Diverter valve Vs. True third function #8
I've had a diverter for my grapple for years, works very well for me. On some machines, they are much easier to install than a true 3rd function setup.
   / Diverter valve Vs. True third function #9
I have the diverter valve and it works great the only problems I have had are as follows.
After I installed it the constant opening and closing created a current surge and the button I used although rated for the current couldn't handle the constant surge, so I had to install a relay and let the button control the relay. No big deal just a live and learn thing.
The other thing is more of a coordination deal. I forget that when I let go of the button if I have the loader lever to one side or the other the bucket moves and startles me. That isn't really a problem but it is a drawback. The only problem with this one is that I do not use the grapple enough to get used to this little tidbit and even when I get pretty good at I forget the next time I use the grapple.
This is the valve I used. Finding a button is a little more difficult because all of the loader levers are different. I got lucky and could take the handle apart because it split in too and make a hole to install a button, then the shaft was hollow and a great place to run the wires. Have fun with your adventure mine was interesting.
12 VDC 13.2 GPM SAE 8 DOUBLE SELECTOR VALVE
   / Diverter valve Vs. True third function #10
That's the same valve I bought - I ordered two, and tried recently to get a third - unfortunately, this is the response I got from Surplus center - "sorry, but that was a surplus item and is no longer available, nor will it be. We have no other information on it."
The only types surplus center shows now are dual solenoid, and they're not real clear on exactly how they work.
The nice thing about the one Guesseral linked to is that they STACK - my two will stack, and the default flow is thru BOTH valves to the other side, which will go BACK to the original bucket curl cylinders - then the ports on top will each run their own circuit when I push their respective buttons.
One thing that may help switch life would be a clamping diode across the switch ( or better, across the valve coil) - when you open the circuit, a coil wants to create a big reverse polarity spike and that's usually what takes out switches, contacts, etc - the diode absorbs the spike but still allows the FORWARD current to operate the coil... Steve
2008 Ford F-350 4x4 Pickup Truck (A50323)
2008 Ford F-350...
NANCE UNDERGROUND CONDUIT BOX (A50854)
NANCE UNDERGROUND...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
New Lewis Brothers MFG DB2 Poultry Housekeeper (A51039)
New Lewis Brothers...
2018 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A50323)
2018 GMC Sierra...
CUSTOM ALUMINUM 16FT CAR TRAILER (A51222)
CUSTOM ALUMINUM...
