Diverter valve install for grapple
   / Diverter valve install for grapple #1
jcummins
Veteran Member
Creal Springs, IL
Kubota M7040, F3680, Mule Pro Fxt
I plan on installing right over the top of where the quick connects are for the loader. Debating whether to tie in by using quick connects or tieing into the line on the loader without quick connects. Like opinions. Quick connects is going to add a lot of 'bulk' to hoses in the area of the valve. I probably will never take the loader off. I will not bulkhead the quick connects for the grapple...leaving them hanging (which I've done on another tractor and it worked fine), keeps the option open to re-position the hoses to the rear for a 3rd functioning hydraulic hookup there.
On quick connects, there seems to be an endless variety of these. If the connector is ag style with the ball, are these all interchangeable? Will a normal ag style connector connect into the quick connects that is on the loader.
   / Diverter valve install for grapple #2
If you do Not need a quick connect, don't use one... they will slightly reduce the total flow, and they add expense, bulk and possible leaks. If you need them they are worth the problems.
Most Kubota quick connects are Pioneer... KennyV
2006 GMC 4500 Bucket Truck with Altec AT200 - 34FT Working Height (A51039)
2006 GMC 4500...
2017 Isuzu NPR Crew Cab 14FT Landscape Dump Truck (A48081)
2017 Isuzu NPR...
2017 Harley-Davidson FLHTP Police Electra Glide Motorcycle (A49461)
2017...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
2014 Dodge Charger Sedan (A48082)
2014 Dodge Charger...
Adams Conveyor (A51039)
Adams Conveyor...
