Ditch witch for tree stump removing?
   / Ditch witch for tree stump removing? #1
Sigarms
Super Member
Mid north west in the state of N.C
F3080
Have 6 stumps that I still need to take out. Smallest is 3" diameter, biggest is around 16".
Mentioned this to a friend, and he tells me that he has a Ditch Witch that can do the job.
I know you have the right tool for the the job, so I'm wondering if I could actually use his ditch witch.
Only reason I'm wondering is I know this guy pretty well, and he made some "statements" on other subjects that I know for a fact is wrong, so I'm questioning his judgement.
Anyone use a ditch witch to remove tree stumps? Pros or cons?
Just looking at "clearing" the stumps, put some topsoil on and grow some grass.
   / Ditch witch for tree stump removing? #2
I'd think if used to trench around the tree and sever the roots, that it would (could) work real well.
Sounds like it would be worth a try, and if he says his will do it, take him up on showing you how well it works.
Nothing to lose, IMO.
I don't think it would chew up the stump itself, but maybe that is even possible at least for the small ones.
Thks
That was what I was thinking.
Only thing I was worried about was if it dug alot of dirt up as well and clean up.
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A54814)
2014 Peterbilt 384...
TEST YOUR BID BUTTON! (A52706)
TEST YOUR BID...
2009 VOLVO VNM DAY CAB (A54607)
2009 VOLVO VNM DAY...
SHOP BUILT FLARE STACK (A53843)
SHOP BUILT FLARE...
2013 International DuraStar 4300 Crew Cab Mason Dump Truck (A51692)
2013 International...
VERMEER NAVIGATOR 53 D23X30111 DRILL (A51406)
VERMEER NAVIGATOR...
