Rotary Cutter Ditch Bank Rotary Cutter ?
   / Ditch Bank Rotary Cutter ? #1
Neophyte
Platinum Member
ME
John Deere 3320 eHydro with 300CX FEL
Does anyone know if someone makes a light duty ditch bank rotary cutter (or similar) for compact utility tractors (30HP range)? This one from Woods is rated for 40-90HP tractors and requires a Cat II hitch.
http://www.woodsequipment.com/catalog/sub2_ag8.html
I have about 600' of private road on an old railroad bed with banks on either side and it is overgrown. What else could I use for this?
Also, what is the difference between a Cat I and Cat II 3pt hitch?
Thank You.
   / Ditch Bank Rotary Cutter ? #2
Go to the bottom this page for a good explaination of the Cat 1 and 2 differences. Can't help you with a cutter cept I use my rotary and back up to my ditches, takes a while but works.
   / Ditch Bank Rotary Cutter ? #3
I have a friend that attached and Agri 38 inch cutter on the side of a carry all frame. he mad his pivot the 2 lift pins and used a 90 degree box off his old cotton picke to transfer the power. The top ling is hooked to and winch that allows him adjustment to the bank slope. He used mostly new stuff so his rig is a bit expensive. Im makeing one from a five foot cutter that will do the road sholders here before the county can do them.
   / Ditch Bank Rotary Cutter ? #5
hazmat,
Good choice. This mower is available from 5-6 MFG. They all do the same thing and have 24"-40" flail cutting heads.
   / Ditch Bank Rotary Cutter ? #6
That's an interesting concept. How well do they work, and how much does one of them micro-mowers cost? I didn't find any price information on the web site.
Kelvin
   / Ditch Bank Rotary Cutter ? #7
Check out the mowers (rotary & flail) to fit compacts to row-crop tractors....from VMC-ORSI, LLC.
www.vmc-mow.com
Three point hitch rear and hydraulic side shift ditch bank cutters from 60 inch cut to 84 inch cut.
Three point hitch reach mowers from 10 - 20 ft reach.
For a dealer near you call 864-940-1625 or email to gary@vmc-mow.com
edv
Ditto what Kelvin asked. I'm curious about the cost.
What is the ballpark cost on one of the 128H micro-mowers with FL40 or HD36B head?
What is a ballpark cost on the VMC RD-160 Ditch Bank Mower and VMC RB110 Utility Boom Mower.
Are these things only good for grass or can they handle heavier brush, small trees, etc.?
Taylortractornut,
I would be interested in seeing pictures of your friends setup or your setup when you are finished. Please post pics when you get them.
Thank You.
   / Ditch Bank Rotary Cutter ? #10
That one is pretty cool too. However, it always makes me nervous when there is no price posted. /forums/images/graemlins/smile.gif or even a ballpark price. Perhaps it is one of those "if you have to ask the price you can't afford it" situations.
The one site said it would pay for itself in 180 hours. That kind of depends on the rate you charge per hour.
2020 Nissan Rogue SUV (A51694)
2020 Nissan Rogue...
2016 Autocar Xpeditor Garbage Truck (A51692)
2016 Autocar...
2010 MQ POWER 25KW GENERATOR (A52472)
2010 MQ POWER 25KW...
Cat TH407C Telehandler (A52748)
Cat TH407C...
UNUSED PALADIN SKID STEER HYDRAULIC BREAKING HAMMER (A51243)
UNUSED PALADIN...
