Disk vs Tiller for Ford 1300
   / Disk vs Tiller for Ford 1300 #1
Ythdude14
SALEM
Ford 1300
I recently bought a Ford 1300 to work on the 5 acres we bought and built on here in Alabama. The dirt here is red clay. Lots of red clay. I need to break the ground up and seed grass on about an acre of it around the house. The red clay is like concrete.
What would work better? A disk set or a tiller or would something else work better? I only need to scratch the top 2-3 inches to give the grass a chance to take hold.
Also, how big would I be able to go on a disk set or a tiller?
The 1300 is a 16 hp and 2WD. One of the back tires has liquid in it, the other I am not sure of.
I use a 4' bush hog that came with the tractor when I bought it last month.
Any help is greatly appreciated.
   / Disk vs Tiller for Ford 1300 #2
A tractor that size with a disc would be about useless IMHO.About the same as an ATV with a disc.I would advise plowing first(Inexpensive middle buster/potato plow about $150);then a tiller.You need to break the top layer and then turn over/mix.
   / Disk vs Tiller for Ford 1300 #3
Indubitably, PTO powered roto-tiller; a tad wider than your rear tire width, outside-to-outside.
Work soil only when it is crumbly.
I would check liquid in rear tires soon. If you run down hard road at 10 - 12 mph having just one rear tire filled may effect emergency breaking dramatically, with potential for a spin/rollover.
   / Disk vs Tiller for Ford 1300 #4
TractorData.com Ford 13 tractor transmission information
i like the idea of middle buster/potato plow or bottom plow/moldboard plow. abilty to sink it down and turn over old growth (roots/weeds/old grass)
would then go with a tiller.
the tiller will more like respond better and less times shutting everything down and getting the razor knife out, tweezers, needle nose plyers, wire cutters, a couple size straight end screw drivers, to untangle stuff wound up on the tiller tines.
a disc alone most likely will not get down to depth without running it across a lot (at least not on this farm).
disc is more for farm/field work. and can leave some descent size clods. a tiller on other hand more likely to break up the clods.
adding to list of stuff, a drag harrow or chain harrow. to drag across it all and smooth stuff out and clean up final clods / dragging grass clumps out. this is more of final touches on it all.
   / Disk vs Tiller for Ford 1300 #5
Another plus for the "middle buster"type plow;they don't plug up.Tried to work some new ground(that had been brush) and they plugged all most instantly.Slow going for sure but they do work.Another fairly inexpensive tool is a three point cultivator,does a decent job on lightly worked ground.
2000 INTERNATIONAL 4700 (A52472)
2000 INTERNATIONAL...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A52748)
NEW 2025 Load...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2008 Ford F350 Bucket Truck (A47384)
2008 Ford F350...
