Disk Size
   / Disk Size #1
Beavis
Kansas
JD 4720
What size disk are you pulling with your 5083E, 5093E, or 5101E ?
THANKS
   / Disk Size #2
I pull a very old (1960's) set of Ford 10' transport discs. The tractor handles them fine, but they probably don't cut as deep as some of the newer ones out there.
   / Disk Size #3
In wet, heavy ground a 10' would be ideal. Dry conditions and a 12' disc would be good. The problem with these tractors isn't the hp so much since Deere is pushing the hp up on them but its the weight. The tractors loose traction if you hook too much to it and it will dig itself in fast.
1999 Ford F-550 12FT. Flatbed Truck (A51692)
1999 Ford F-550...
2016 Chrysler 200 Limited Sedan (A50324)
2016 Chrysler 200...
2022 SIDUMP'R 48FT TRI AXLE SIDE DUMP TRAILER (A54607)
2022 SIDUMP'R 48FT...
2011 Caterpillar 299C Two Speed Compact Track Loader Skid Steer (A52377)
2011 Caterpillar...
2013 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2013 FORD F-150 XL...
44029 (A51692)
44029 (A51692)
