discontinued attachments specs
   / discontinued attachments specs #1
jimg
Veteran Member
In your travels on the net have you come across data for attachments like hay equipment etc. Right now Im looking for specs on the NH 310 and 311 sm sq balers. However, Ill be interested in other equipment as well. Ideally Id like to find a site for attachments like tractordata.com is for tractors.
   / discontinued attachments specs #2
I have no idea whether there is a web site dedicated to this information, I have an old Implement & Tractor Redbook (1988) which lists the NH 311 and 316 balers, as well as any virtually any piece of ag equipment sold in the US at that time. General specs are: 14x18 bale, can make a bale 12-52 inches long, came with either spring or hydraulic bale tensioners, plunger stroke is 30 inches, plunger speed is 79 stroke per minute, pickup width at 61.5 inches for the 311, 67.5 for the 316, feed opening for the 311 at 258 sq. in., the 316 at 299 sq. in., weight for the 311 PTO driven, pull type at 2768 lbs., the 316 at 3230 lbs.
Thanx!! Does your book mention whether it can be rigged for wire too? It seems that the 311 would be roughly comparable to the current 565 and the 316 roughly a 570.
I might have to find one of those books as it sounds pretty useful. Are they hard to find?
Thanx again for your help...much appreciated!!
   / discontinued attachments specs #4
Both balers are wire or twine compatible. The I&T Redbook is included as a regular edition with a subscription to Implement and Tractor Magazine. As for older editions, I don't know how difficult it would be to find one. Here's the website Implement and Tractor
Thanx much!
2017 Polaris 500 Ranger Diesel Utility Cart (A50324)
2017 Polaris 500...
UNUSED FUTURE SB05 HYD BREAKER (A51248)
UNUSED FUTURE SB05...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A53426)
2018 FREIGHTLINER...
2020 CATERPILLAR D6K2 LGP CRAWLER DOZER (A51246)
2020 CATERPILLAR...
ECONOLINE TRAILER, INC (A50323)
ECONOLINE TRAILER...
UNUSED MOWER KING 67" QUICK ATTACH FLAIL MOWER (A51248)
UNUSED MOWER KING...
