Disc with a BX2200
   / Disc with a BX2200 #1
Bowhunter
southwest Indiana
Kubota BX2200
Has anyone disced with a BX? I'm considering buying a 45" 3 pt. lift tandem disc to use for food plots, but want to make sure the BX will be able to lift it and pull it. It looks like the disc may be a little too tall for the short BX, so I would first lower the pins before doing anything else. Opinions?
   / Disc with a BX2200 #2
I don't think the BX2200 will have enough traction to pull a disc, especially on a second pass once the ground is loose. Power would probably be adequate for a 45" disc, but I suspect you'd just spin the wheels. I'd suggest going with a rototiller. Very easy to pull and it does a real nice job of breaking up the soil.
   / Disc with a BX2200 #3
I tried a disc once and learned after 5 minutes that I was going to ruin the tractor if I kept it up.
It just isn't big enough for that.
   / Disc with a BX2200 #4
On the Landpride website they have a video you can download.....and it appears to be a Kubota BX2200/2230??...pulling a 48" DH10 model disc. Once you find the DH1048 under "products", look on left side margin for "Click Here For DH10 In Action" in yellow box. In the video, the 'Bota looks like it's doing pretty well with it.
Thanks guys. I've decided to give it a try. For 20% off (and roughly $1000 cheaper than a tiller) I couldn't pass up this disc. I hooked it up to the BX to unload it from the trailer and it is sized perfectly for it. I will need to lower the lift pins around 6 inches, because it now only lifts it 4 inches off the ground.
I would rather have a tiller, but two of the areas I will be planting were thick brush/small trees until recently and the disc will do better with the small tree stumps. I think the BX will do ok with this disc in low 4wd.
   / Disc with a BX2200 #7
I am in a similar situation, can you tell me what disc you bought. Also, after you give it a try will you post your results?. Much appreciated.
I sure will. It is a Worksaver brand 45" tandem lift disc. I bought it at Rural King, which is similar to TSC. It is normally marked $389.99 but I caught it on a sale for 20% off. After I get it modifed and get to use it I'll post some pics. It may take a few weeks for me to get that all done though.
   / Disc with a BX2200 #9
Bow, also curious to see how it works for you.
And post pics PLEASE.
At times when I'm using my box blade, if traction becomes an issue, I put about 1/2 load of dirt in the FEL. The extra weight helps with traction.
ron
   / Disc with a BX2200 #10
Ron's tip does work well. I also drop tire pressure to ~15psi ... kinda like a real tractor /forums/images/graemlins/wink.gif
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
2001 KINCAID PRO-SERIES 1200V2 HYDRO SEEDER (A51406)
2001 KINCAID...
2022 Ford F-550 Cab and Chassis Truck (A50323)
2022 Ford F-550...
Kohler 50 Generator (A50774)
Kohler 50...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
EZ-GO D499 Electric Golf Cart (A51694)
EZ-GO D499...
