inveresk
Platinum Member
I've recently bought an 11 acre farm of which about 3 acres are in meadow and orchard that haven't seen a plough or mower for some time and the field is rough, full of bumps and hollows. The soil is quite heavy and a drainage ditch has been ripped across the meadow to conduct rainwater in winter which can be considerable (I'm on one of the gulf islands in BC, Canada). I want to plough it, level it and re-sow it but am not sure of the best equipment to get for the tractor I've ordered (Kubota 3130). I'll have to cut down some of the overmature fruit trees and do a bit of stump pulling first but once that's done, is it best to use a disc or furrow plough to turn over the soil? What are the benefits and advantages of each? I' ve been advised against rototilling. How is it best to level out the hillocks and hollows? The Kubota will come with a FEL and backhoe but do I need anything else such as a scraper blade? Once it's level, do I simply break up the sods with a furrow or do I need to use some other implement first? I'd like to keep horses in the field once it's been resown and so the ditch will need to be filled in or fenced off. I'm inclined to install a field drain, 8" dia, surround it with pea gravel and level off but am not sure if this will work in heavy soil. If anyone has had similar problems and overcome them, any help or advice would be appreicated.
George G.
George G.
